Is this normal.
ecain63
RE: Re: Is this normal.
Post by ecain63 » Fri Sep 18, 2009 2:39 pm
they were all 36 the other day.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
PoRToS
Post by PoRToS » Fri Sep 18, 2009 2:51 pm
How about the brakes? If a brake caliber (or one piston in the caliber) freezes on just a bit, creating an uneven force against the brake disc, thus creating a wobble.
And after a bit of use the calibers get up to "working temp" and the little freeze is gone and *tsadam* no wobble!
GardinerG
Post by GardinerG » Fri Sep 18, 2009 2:54 pm
Hmmm, I have mine at 42 but am going to drop them. I wonder if your pressures are too low and the front tyres are getting flat spots...
estrop77
Post by estrop77 » Fri Sep 18, 2009 7:25 pm
wheel wobble around 70-80mph is a sign of buckled alloys. any probs balancing them??
Rich
RS6 Saloon - 03 Mugello Blue / Silver. Fully loaded. Standard and mint used at weekends only.
drybeer
Post by drybeer » Fri Sep 18, 2009 8:38 pm
Mine are 46 presently having had some heavy duty load lugging recently - but normally 40.
Grant have you found 42 specifically is better on handling but still OK on wear in the centres?
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
GardinerG
Post by GardinerG » Fri Sep 18, 2009 11:18 pm
42 gives more even wear even with hard driving but is sooo hard (275/30), hence I want to lower the pressure.
GardinerG
Re: RE: Re: Is this normal.
Post by GardinerG » Fri Sep 18, 2009 11:19 pm
estrop77 wrote:wheel wobble around 70-80mph is a sign of buckled alloys. any probs balancing them??
yep, but surely it would always be the case rather than intermittent?
ecain63
RE: Re: RE: Re: Is this normal.
Post by ecain63 » Mon Sep 28, 2009 7:32 am
Sorry, been on hols for the week.
There were no probs balancing as far as i know. It was only done a couple of months ago. I might try upping my psi to 40 and see what happens. Got home off the plane last night after 10 days away and the wobble didnt show so im not sure what to make of it.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
rob8457
Post by rob8457 » Mon Sep 28, 2009 10:11 am
Its only 1 thing had it on mine i know you said you had them ballanced but i would check them again it can only be the ballancing perhaps they did not do it right?
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
ecain63
Post by ecain63 » Mon Sep 28, 2009 2:38 pm
It did it before i had them rebalanced too. I think i'll pump the tyres up a bit and see how it goes.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Cornishmoocher
Post by Cornishmoocher » Mon Sep 28, 2009 5:45 pm
Eddie, take it back and get them to check the balancing out. I had some feck wit do mine and it wasn't till a few days later that i discovered that over 90 it shoock like a little dog havin a <beep>.
I took it back and tld the fitter who denied all knowledge even tho he was commenting on my car and wanted to have a go... I persuaded him it was in his interest to re- do it for free, or otherewise he can explain to his boss why he was personally responsible for losing an account with 175 vehicles on it..... Funilly enough on the day that he first did it, the machine "must have had a fault" because they were completely out.
It's all Bollox.
drybeer
Post by drybeer » Mon Sep 28, 2009 6:34 pm
A customer of mine used to get bad wheel wobble when his wheels had a lot of dirt on the inside of the wheel rim..
This was on a C5 allroad, so similar.
Are your wheels clean on the inner rim?
ecain63
Post by ecain63 » Mon Sep 28, 2009 7:37 pm
Got it booked in for a rebalance on saturday so we shall see what happens. I have upped my psi's to 40 to see what effect it has. Anyone have a recomendation as far as tyre pressures go? They are Standard P Zero Rossos 255 / 35 / 19 btw
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Users browsing this forum: Google [Bot], rs4wagon and 63 guests
