rattle from front wheel ''area''
philroach
Post by philroach » Fri Sep 11, 2009 8:01 am
Have had a rattle for some time now , that seems to come from the front drivers side wheel area , i can hear it when window is down
have had h&r's with arb's fitted by the grizzmeister , o/s/f lower bearing arm renewed , n/s/f lower bearing arm checked and cleared , and both CV gaiters replaced....
still have rattle which comes up over short sharp bumps in the road , or in the case of my unmade road , rattles a lot . Sounds like a pair of domino tiles being shaken together, best i can describe it as , and i havent lost any domino tiles either !!!
any ideas would be much appreciated
cheers
phil
Daveperc
RE: rattle from front wheel
Post by Daveperc » Fri Sep 11, 2009 9:21 am
No idea mate - maybe just shut the window??
Dave
philroach
Post by philroach » Fri Sep 11, 2009 9:47 am
why o why didnt i think of that at the same time as i wrote that i had checked for missing domino's , funny man
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Daveperc
Post by Daveperc » Fri Sep 11, 2009 9:51 am
Seriously - have you checked the door/window? Not had a problem on the RS, but one of my SAAB's sounded rattly with window open till I realised that it was the window mechanism itself which was slightly loose, but could only move when the window wasn't shut!
Dave
Post by HYFR » Fri Sep 11, 2009 10:25 am
does it "knock" / "click" on full lock or when turning the wheel. . .
Post by Shoppinit » Fri Sep 11, 2009 1:09 pm
Are all the exhaust mounts / fittings present & tight? Should be reasonably easy to check.
philroach
Post by philroach » Fri Sep 11, 2009 7:42 pm
everything seems tight exhaust wise , and is fine on full lock , just a little rub on the inside of the wheel arch mud cover thingy , grizz has seen that and says its normal , so there is something else causing the problem , dammit
johnny11
Post by johnny11 » Fri Sep 11, 2009 8:04 pm
i had a similar thing a while ago, kept getting this rattle noise on divers side, every time went over a little bump or big one, this metallic rattle would appear, then one day my 7 year old was in the back and i asked her if she heard the noise, to which she replied "yes dad thats the £1 coin i put in the back door ashtray thats rattling around" she took the £1 out and the noise went. The little moo. just check to see if anything in the ashtray, yu never know!!
MountainMutant
Post by MountainMutant » Sat Sep 12, 2009 6:10 pm
Mine had very similar but more of a squeak that could only be heard with the windows down. Local garage said it was one of the suspension/steering joints and was a common Audi problem.
They made a pin prick hole in the knuckle joint and squirted grease in and the noise has gone :O) Saved buying a new part.
MM
2017 RS6 PE Nogaro 💙
philroach
Post by philroach » Sat Sep 12, 2009 8:03 pm
its definitely outside , having driven down my road with head out of window !!
mbedford
Post by mbedford » Sun Sep 13, 2009 7:00 pm
I've just had the same problem. I couldn't find it at first so just dismissed it. Then noticed a slight vibration on acceleration which disappeared when coasting. Have just been under the car today and found the nearside inner cv boot has split and when you grab the driveshaft and wiggle it it rattles. I'm hoping that replacing the cv joint will sort both problems and that I won't have to resort to replacing the driveshaft as well.
Users browsing this forum: srichards, steve2003rs6 and 122 guests
