Break Disc warped? Any ideas?
sckrs4
Post by sckrs4 » Wed Aug 19, 2009 8:15 pm
Hi
Just noticed while slow breaking there is a slight vibrating noise/break judder. Having looked at the front left disc the outer perimeter of the disc can see a slight etching. Seems like its eating into the disc.
Any ideas?
s.
duud40
RE: Break Disc warped? Any ideas?
Post by duud40 » Wed Aug 19, 2009 10:01 pm
Fit other brake pads and it might remedy by itself. Other than oem. I run Ferodo ds2500 and i`m very happy.
P_G
Post by P_G » Wed Aug 19, 2009 10:52 pm
Has anyone used EBC yellow or red stuff pads on their RS4? Are they worht invcesting in as I have warped rear disks and I need to decide whether I buy replacements, get them skimmed or invest in agressive pads which may cure the situation.
klauster
Post by klauster » Thu Aug 20, 2009 2:30 pm
I have my old brake disks to try and skim, they are less then 6 month old, anyone know of companies in Leeds area?
P_G
Post by P_G » Thu Aug 20, 2009 2:58 pm
I only know of a company up here in Newcastle that do the work. If you want to give me your discs they next time we meet up if you are not in a hurry I can get them to skim them for you?
I believe the price is gong to be around 40-50 quid for the pair to be done. Awesome GTi do on car skimming as well at 50+VAT which is supposed to be better than off car skimming as it give perfect allignment.
P_G
Post by P_G » Thu Aug 20, 2009 3:29 pm
Klauster, just found this;
http://www.skimmydiscs.co.uk/find_a_lathe.html
Put in your region and it will come up with all the garages that have brake lathes, most are Pro-Tech. Floating disks I believe form memory have to be taken off the car to do, the rear disks IIRC are one piece so can be done on the car.
Having my rear ones done next Thursday, I am so looking forward to judder free braking again!
klauster
Post by klauster » Thu Aug 20, 2009 10:06 pm
thanks Graeme :)
Phillydriver33
Rotors
Post by Phillydriver33 » Sat Aug 22, 2009 6:51 pm
Go to this link http://jhmotorsports.com/shop/catalog/ this guys in california he makes alot of good stuff for audis and vw.
i bought the first set of rotors he made they work great and the dealer even put them on for me.
They are just the outer ring of the front rotor but they are slotted which will have more strength and less chance for warping. Also the cross drilled OEM rotors make circles around the rotor which may cause grooving in the pad.
it like these they are cheaper than OEM and look and work great.
tell him the Dimitri from philly recommend you
P_G
Post by P_G » Sat Aug 22, 2009 8:45 pm
Just a pity they only do outer disks for the front rotors; slotted front and rear disks would have been better.
Phillydriver33
Post by Phillydriver33 » Sat Aug 22, 2009 9:21 pm
they have them both for the front n the rear on this website. Check them out JHMmotorspots
i just bought the rears slotted for 510 for the pair
its a good price and they are better than the stock
i dont like cross drilled they create too mnay problems and weaken the rotor
P_G
Post by P_G » Sat Aug 22, 2009 9:57 pm
For whatever reason the second page didn't upload first time of viewing, see them now.
Definitely worth looking at as fronts and rears equate to approx 580 GBP plus shipping. So by the time you add that and VAT then 700 GBP
