Gear knob removal
RE: Gear knob removal
push the lower part of the knob down (trim around the stick) then pull out the button and secure with a cable tie,then a good tug and it should come off,be very carefull with it though if you let the button go back in its a real pain in arse to get back on (the button mechanism has a bell crank in it),hope that helps
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Cheers for that - Ill take a look when I dont need the car for a bit (just incase)
- martinjpainter
Re: Gear knob removal
I tried to remove my gear shifter on my C6 RS6. I tried pulling the push button out and lifting the knob, but it would not move.
Any clues?
Any clues?
found this on you tube but for a B6 A4 principles should be the same
https://www.youtube.com/watch?v=ojObZBmjDiI
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
