Juddering from pull off full lock??
When I pull away on full lock there is a wierd juddering/vibration??
Is this normal on an RS6, the wheels are standard but its running Bilstiens
Matty
Matty
yep!..
this... http://www.rs246.com/index.php?name=PNp ... ic&t=77026
what I will say, is no, I don't have an RS6 (yet), but ive owned 3 other 4WD audis, its pretty common - don't lose sleep, but get it checked if its real bad......
Its not horrendous and somehow seems normal but I know the car has recently had laser 4 wheel alignment done so just thought I`d check!S4WON wrote:yep!..
Its normal for permenant 4wd drive cars to have a bit of 'judder' on full lock. If its really bad then get it checked, but nothing to worry about if not. Its all to do with the wheels turning at different speeds when under full lock, causing grip issues as they fight the diffs.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Normal. There's a fairly interesting explanation on why it does this, but I can't remember what it is.
^^^^^ 4 wheels trying to turn at the same / similar speed when the inside wheel is almost at standstill due to full lock. This causes inside wheels to drag.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
275 Vreds.
Miltek Resonated.
Hi Flow filters.
- Top Gear
You may also find that the front wheels are touching the arch liner, mine does this, took grizz and i about 30 mins to figure out what it was, driving back and forth on full lock. It is very common- sounds and feels like a graunching bearing.
It's all Bollox.
Users browsing this forum: No registered users and 85 guests
