Strutbrace
Strutbrace
Can you get a front strutbrace for the b7 S4? My car seems to lean alot on the corners?
- BlingBling
RE: Strutbrace
Not sure about a front strutbrace but have you fitted the RS4 RARB? This does a lot ot reduce understeer and leaning.
- BlingBling
RE: Strutbrace
Addtionally lowering the ride height will reduce the amount of lean. You may have to make a compromise on the ride though. There are some H&R springs for sale by P_G from the RS4 forum.
Re: RE: Strutbrace
Is this a straight swap, B7 RS4 to B6 S4 ???????????BlingBling wrote:Not sure about a front strutbrace but have you fitted the RS4 RARB? This does a lot ot reduce understeer and leaning.
Last one dead's a sissy.
- BlingBling
Re: RE: Strutbrace
90%. The RARB is a stright fit. However the bushes and the brackets needs changing. Search either RS246, Audizine, Audiworld for more info including guides showing how to DIY.B6S4John wrote:Is this a straight swap, B7 RS4 to B6 S4 ???????????BlingBling wrote:Not sure about a front strutbrace but have you fitted the RS4 RARB? This does a lot ot reduce understeer and leaning.
