Sidelights
ShaneyB
Post by ShaneyB » Wed Jul 08, 2009 9:54 am
Just changed my driver side parking light. A bit fiddly but done in 5 minutes.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
elmo
Post by elmo » Wed Jul 08, 2009 5:29 pm
Shagga wrote:Just changed my driver side parking light. A bit fiddly but done in 5 minutes.
Shane,
I changed my driver side out too when I got the LED lights. It was a little bit fiddly, but everything unclipped and went back in no problem.
If you haven't got the LED replacements, I would recommend them. They look the same as the main Xenon bulbs :shock:
A much improvement over the standard ones.
ShaneyB
Post by ShaneyB » Thu Jul 09, 2009 8:29 am
Elmo,
Where did you get yours? Do you have a part number?
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Pete.S
Post by Pete.S » Thu Jul 09, 2009 8:39 am
Keep us updated on these Elmo please mate, I must've got through 20 sidelight bulbs, it's the one small but irritating reliability issue I have wih this car! I do do a lot of night driving though, but it'd be interesting to hear how long these LED ones last. Apparently the bulbs fail so often due to excessive current being sent throught them on start up because of charging issues.
PS when I change mine I simply take off the cap at the back of the light unit (which is held in place by a hinged metal clip) and pull the bulb holder out; bit fiddly, and on the driver's side it means removing the ribbed air pipe, but only takes a couple of minutes.
ShaneyB
Post by ShaneyB » Thu Jul 09, 2009 11:06 am
Yeah Pete,
It looked worse than it was and for once I'm glad I have small hands.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
elmo
Post by elmo » Thu Jul 09, 2009 1:59 pm
Shane,
Got mine from http://www.ultraleds.co.uk/automotive-bulbs-c-101.html
They are the H6W BAX9 bulbs.
Will post a picture to show the difference.
Cheers,
Elliot
Post by chunky79 » Thu Jul 09, 2009 7:41 pm
Not the best pic but here's mine
chris.s
Post by chris.s » Fri Jul 10, 2009 11:38 am
Hi,
I like the idea (and look) of these. Did you need any ballasts or is the car happy with the LED bulbs and not giving any errors?
Chris
2003 S4 Avant, Moro Blue,
Post by chunky79 » Fri Jul 10, 2009 8:31 pm
chris.s wrote:Hi,
Chris
They are only the side lights mate so no ballasts. I have had the odd error come on the dash from these but don't think anyone else has??
chris.s
Post by chris.s » Sat Jul 11, 2009 12:26 pm
Thanks Mate, Better get some ordered then 8)
BigAustin
Post by BigAustin » Sun Jul 26, 2009 6:04 pm
got some of these new fangled LED`s as recommended 8)
job took less than 5mins , both sides; and that time included checking the oil :D
they do look alot like xenon headlights now, they seem that bright I`m not sure I`ll need to use headlights at all :shock:
marv
Post by marv » Tue Sep 15, 2009 11:27 am
Hi all, I see chunky has mentioned that he had errors due to these leds, has anyone else had these errors?
| '04 S4 Avant (B6) | NOW SOLD :(
BlingBling
Post by BlingBling » Tue Sep 15, 2009 3:16 pm
Had mine installed about 1yr now and never had any errors or warning symbol on DIS.
marv
Post by marv » Tue Sep 22, 2009 8:59 pm
For info, I fitted the LED sidelights tonight (well, one...), and I'm really impressed. I managed to break one of the LED units as I was putting it in, so at the moment I've got one LED and one regular bulb!! Means I was able to take a pretty good comparison picture though!
I haven't got my xenons on here, but the LED matches the white light of the xenons a lot better than the old yellow sidelights. It just looked wrong to me having yellow sides & nice white xenons.
For anyone that's reading this who's thinking of replacing their bulbs I'll add my experience: I had to remove a piece of cowling on the passenger side (easy - no screws involved), and what I think was the air intake for the cabin on the driver side, (again, pretty easy, but slightly fiddly to replace). Once these were off it was just a case of unclipping and removing the rear cover of the light cluster, and pulling out the bulb holder. This is where I definitely agree that small hands are useful! Not a hard job really, probably 30 mins for the first time you do it, and that's if you're going carefully and are a bit hamfisted like me!
LED vs bulb sidelights
BlingBling
Post by BlingBling » Wed Sep 23, 2009 8:59 am
marv wrote:For info, I fitted the LED sidelights tonight (well, one...), and I'm really impressed. I managed to break one of the LED units as I was putting it in, so at the moment I've got one LED and one regular bulb!! Means I was able to take a pretty good comparison picture though!
The same happened to me. When I was twisting the bulb into place the top part came off. Ultraleds replaced them no qualms. Send them back.
