No-Go on Warranty Work
P_G
Post by P_G » Mon Jun 29, 2009 9:55 pm
Are the standard RS discs not Brembos anyway as well as the calipers? So what is the difference with the new Brembo discs and are you using the OEM calipers with them?
karl
RE: Re: No-Go on Warranty Work
Post by karl » Mon Jun 29, 2009 10:59 pm
22K on the clutch.
The Brembos came with the braided lines supplied. Pics soon.
karl
Post by karl » Mon Jun 29, 2009 11:04 pm
P_G wrote:Are the standard RS discs not Brembos anyway as well as the calipers? So what is the difference with the new Brembo discs and are you using the OEM calipers with them?
The new discs, apart from being bloody monsters, have much larger holes drilled through which no doubt helps the cooling and perhaps will avoid them getting blocked. I have kept the same (original) calipers. APS recommended I stick with the original Audi pads rather than Pagids as I'm not going to be tracking the car.
If the original discs are Brembos (which I would doubt) then they have clearly been wrongly spec'd for this car.
P_G
Post by P_G » Mon Jun 29, 2009 11:04 pm
Are they the same calipers and pads though or are they a complete new set?
rAudiguy
Post by rAudiguy » Tue Jun 30, 2009 3:58 pm
karl wrote: APS recommended I stick with the original Audi pads rather than Pagids as I'm not going to be tracking the car.
The original pads are Pagids mate, I guess they mean rather than upgraded to a better pagid pad like blue or yellows!
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
P_G
Post by P_G » Tue Jun 30, 2009 5:19 pm
IIRC the caliper and disc assembly was formulated for Quattro GmbH by Brembo because the calipers are the same as the Porsche 996 ones. That's why I was curious about the disks, whether indeed they were 385 mm discs rather than what we have which is 365mm and the OEM are 2mm crossdrilled wheras the 385mm are 3mm crossdrilled holes.
Have you got part numbers on your invoice from APS? I would go to them but they are a tad bit far for me just to 'pop by' to.
rAudiguy
Post by rAudiguy » Tue Jun 30, 2009 5:26 pm
Hi Graeme, it is a big brake upgrade, they use a spacer to sit the caliper back to allow the extra 20mm. A friend of mine has just done this with Pagid Grey pads and is raving about them.......... Going to see him in a weeks so will take some pictures for you all. As Karl says the holes are alot bigger and as aposed to the standars disc which has 3 in a line they have 4. Look the business!
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
matthew.lewis2
Post by matthew.lewis2 » Tue Jun 30, 2009 5:49 pm
Don't forget, these are always an option for front brake discs http://www.jhmotorsports.com/shop/catal ... cts_id=373
UAE CARS
2009 Toyota Landcruiser - White -4.7 V8 VXR (SOLD)
2014 Mercedes ML500 - 4.7 V8 Twin Turbo (SOLD)
2008 Audi RS4 - Sprint Blue (SOLD)
2002 Range Rover 4.6 V8 HSE (SOLD)
2007 Golf R32 - Black (SOLD)
2005 Lincoln Navigator - White (SOLD)
UK Cars
2015 Landrover Defender 110 Heritage (SOLD)
2014 Audi RS4 - Sepang Blue (STOLEN)
2003 EP3 Civic Type R - K-Pro Remapped (SOLD)
2004 Golf GT TDi 140 - Superchipped to 189bhp (SOLD)
2003 Audi A2 1.4 Tdi
aidanjaye
Post by aidanjaye » Wed Jul 01, 2009 10:15 am
matthew.lewis2 wrote:Don't forget, these are always an option for front brake discs http://www.jhmotorsports.com/shop/catal ... cts_id=373
Anyone using these discs??
