Loss of power with exhaust valve mod???
rikardo
Post by rikardo » Mon Jun 29, 2009 9:33 am
Hi All
I keep dipping under my car to connect and disconnect those little grren pipes on my exhaust and I'm now certain that i lose power when they're taken off. Yes - it sounds great, but get a marked if intermittent flat spot - occasionally even feels like a misfire at mid-range - and that beatiful 2nd 'kick' at 6000RPM has gone. A real shame 'cus I love the sound. At first I thought I imagined it, but having swopped at couple of times it's definately there. So I now have the choice between sounding great or going fast :(
Anyone else had the same problem or perhaps have an explanation?
approved
RE: Loss of power with exhaust valve mod???
Post by approved » Mon Jun 29, 2009 10:24 am
mines been done and my power doesnt feel down i dont think?
my extra shove at 5000 rpm plus is still there as well...
i know that doesnt help you by way of an explanation but it does confirm something isnt right with yours?
UNI555
Post by UNI555 » Mon Jun 29, 2009 10:24 am
Have you been plugging the pipes? They must be plugged air tight or you'll lose vacuum.
pippyrips
Post by pippyrips » Mon Jun 29, 2009 10:55 am
What he said, sounds like you are getting a vacuum leak, even if you have been attempting to block the pipes.
rikardo
Post by rikardo » Mon Jun 29, 2009 11:29 am
Thanks guys!
That's what happens when you let someone with little car knowledge loose with a pair of pliers. Guess the Gaffer Tape wasn't enough..... :oops:
I'll let you know
gogsyp
Plug them!
Post by gogsyp » Mon Jun 29, 2009 12:45 pm
Just did mine last week.
Put a couple of grub screws into the ends of the black flexi hoses' & tighten the ends up with the end clamps. This will ensure that is no vacuum loss.
Oli
RE: Plug them!
Post by Oli » Mon Jun 29, 2009 2:55 pm
Exactly what the fault was with mine - Make sure they are blocked
baylissboy
RE: Plug them!
Post by baylissboy » Mon Jun 29, 2009 8:19 pm
If you don't block them properly you will effect the whole vac system on the engine, ie secondary air system, inlet manifold flaps etc, eventually you will have the engine warning light on.
Oli
RE: Plug them!
Post by Oli » Mon Jun 29, 2009 10:17 pm
Doesn't put a man light on or store codes. Mine didn't
gogsyp
Man Light
Post by gogsyp » Mon Jun 29, 2009 10:31 pm
My EPC light would come on then go out again and eventually the man. light came on. I guess when this happened, it resulted in a total vacuum loss to the whole system.
http://i889.photobucket.com/albums/ac10 ... p/Hose.jpg
P_G
Post by P_G » Mon Jun 29, 2009 11:06 pm
Have you got this all fixed now gogsyp or do you still need a cpy of my r/r figures?
rikardo
Post by rikardo » Tue Jun 30, 2009 1:05 am
Thanks all!
Problem solved. Plugged the pipes nice and tight and now have great sound and speed to match.
Thanks again for the help :D
gogsyp
All is well
Post by gogsyp » Tue Jun 30, 2009 12:19 pm
I'm all sorted now thanks, just saving up for my X-Pipe & back box from AAS. There is one thing that I have noticed since plugging the rear vacuum pipes, there is now a distinct 'flat spot' at 6000rpm.
I have got no idea why this is but I'm not too concerned because after I get the new exhaust fitted I'm going to get it remapped to iron out any issues.
silverRS4
RE: All is well
Post by silverRS4 » Wed Jul 01, 2009 4:49 am
Has anyone had this noticeable power loss without any vacuum problems or MIL light? My car did it briefly a few times several months ago, but now its anemic all the time and has been for quite a while. According to my VAG-COM data-logs (which can actually log torque output of the engine), the torque is down 30-40 N-m and HP is down 40-45 HP. The car is definitely off and its not just fuel or atmospheric conditions. I've tested all the vacuum lines myself and the power flap, manifold flaps, and exhaust (back box) flaps work properly. I'd like to take it to the dealer, but what am I supposed to do without a MIL? Just give them a bunch of graphs and tells them to fix it?
