Where to buy longer grille after removing fog lights ?
albertpl
Post by albertpl » Fri May 29, 2009 9:44 am
I'm looking for longer air guide grille after removing the fog lights.
Where could I buy the parts like on the pictures bellow ?
ataRS6
RE: Where to buy longer grille after removing fog lights ?
Post by ataRS6 » Sat May 30, 2009 3:51 am
give MRC a call they supplied me with mine
RS6 Avant, black with black wheels, front S6 led lights, rear smoked Led lights, miltek non-res, miltek cat by-pass down pipes, ITG air filters, H&R kit with Arb's, MRC stage 2
albertpl
Post by albertpl » Sat May 30, 2009 9:06 am
e-mailed Lucas @ MRC. I will see what will be the response.
mattler
Post by mattler » Sat May 30, 2009 8:55 pm
Why would you do a thing like that?
Not a dig, just curious
albertpl
Post by albertpl » Sat May 30, 2009 9:02 pm
When you take the fog lights + plastic around it the intake temperature drops down 10-15 degrees Celsius.
I came to this after analysis of VAG-COM and the intake temperatures together with engine ignition <beep>. The ECU is not moving back the ignition that much now. The tests where conducted in several runs 0-200km/h or 60-160km/h.
RS6 Silver Avant, ABT chip, Phaeton brake ducts mod, ECS stainless steel brake lines, engine cooling mod. More to come :) www.rs6club.pl
mattler
Post by mattler » Sat May 30, 2009 9:23 pm
So basically more performance or throttle response. Intersting! May do this myself.
Matty
albertpl
Post by albertpl » Sat May 30, 2009 9:48 pm
the air that gets to the cylinders has certain temperature, the lower the temperature the better engine runs giving more power
the air on standard RS6 + chip is 40 up to 65 degrees Celsius
so taking out the fog lights + the plastic lest more air to the intercoolers thus cooling them down more
Take a look at Sportec RS600 car and the parts that come with Sportec Intercoolers
The easiest thing is to test that with VAG-COM and wath the intake temps.
GardinerG
Post by GardinerG » Tue Jun 02, 2009 11:32 pm
I am interested in these as well.. ;-)
p3u
Post by p3u » Wed Jun 03, 2009 1:10 am
I'd like a set as well! Keep us updated!
albertpl
Post by albertpl » Wed Jun 03, 2009 6:51 am
No luck at MRC. Lucas did not reply :(
I'm looking still ...
