Certified dyno graph:
Locked
ArthurPE
Post by ArthurPE » Sat May 16, 2009 4:03 pm
from a pure independent test agency, not a tuner...
done for auto, motor und sport...to CERTIFY to power
steady state test, not a ramped accel run...
345 Whp...NO correction
it all depends on the dyno, and the results desired by the operator...
http://www.rri.se/spec/view/png/graph/S ... W-Nm-C.png
Lebult
RE: Certified dyno graph:
Post by Lebult » Sat May 16, 2009 4:06 pm
The RS4 has about 20-25% drivetrain loss, so adding 20%, that would be exactly 414 SAE HP.
That picture isnt very big though, I can't make out the numbers on the graph.
Any idea of mods?
Or the type of dyno used?
ArthurPE
Post by ArthurPE » Sat May 16, 2009 4:06 pm
another, compared to the R8, no correction
http://image.automobilemag.com/f/featur ... hart_a.jpg
330 Whp....
dyno dynamics iirc
Lebult
Post by Lebult » Sat May 16, 2009 4:09 pm
Hmm, I don't see it saying WHP on there.
Do you know where this dyno was done??
NA or UK ?
ArthurPE
Re: RE: Certified dyno graph:
Post by ArthurPE » Sat May 16, 2009 4:24 pm
Lebult wrote:The RS4 has about 20-25% drivetrain loss, so adding 20%, that would be exactly 414 SAE HP.
Any idea of mods?
it was a stock car, off the dealers floor, submitted by auto, motor und sport to verify Audis' claims...
it made 258 KW (345 HP) at the wheels...
this site is good http://www.rri.se/
all these guys do is certification dyno testing, that's their business...
ArthurPE
Post by ArthurPE » Sat May 16, 2009 4:27 pm
Lebult wrote:Hmm, I don't see it saying WHP on there.
NA or UK ?
it is uncorrected WHP, it was done at rototest, in Sweden
http://www.rototest.com/rototest-dynamometer.php
Lebult
RE: Re: RE: Certified dyno graph:
Post by Lebult » Sat May 16, 2009 4:31 pm
Very cool. thanks.
ArthurPE
Post by ArthurPE » Sat May 16, 2009 4:34 pm
these white papers are very educational on dynos...losses, etc. http://www.rri.se/index.php?DN=30
ArthurPE
Re: RE: Re: RE: Certified dyno graph:
Post by ArthurPE » Sat May 16, 2009 4:37 pm
Lebult wrote:Very cool. thanks.
here's another RS4 http://www.rri.se/popup/performancegrap ... artsID=281
257 kW (349 PS / 345 bHP)
wheel, not corrected to crank
AntoRS4
RE: Re: RE: Re: RE: Certified dyno graph:
Post by AntoRS4 » Sat May 16, 2009 10:46 pm
Arthur,
please take a look at the s3... any explanation?
http://www.rri.se/popup/performancegrap ... artsID=735
ArthurPE
Re: RE: Re: RE: Re: RE: Certified dyno graph:
Post by ArthurPE » Sat May 16, 2009 11:50 pm
AntoRS4 wrote:Arthur,
yep...it would appear to be significantly UNDER rated...it happens...
both S3's are about the same...it's impossible to have 0% loss, so the only logical assumption is that they are over rated...
335i, 6% in losses, only 4% torque http://www.rri.se/popup/performancegrap ... artsID=647
rumored to be under rated...
SR71
RE: Re: RE: Re: RE: Re: RE: Certified dyno graph:
Post by SR71 » Sun May 17, 2009 12:05 am
There is ~20hp difference between even their own tests on a 06 and 07 RS4...
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
ArthurPE
Re: RE: Re: RE: Re: RE: Re: RE: Certified dyno graph:
Post by ArthurPE » Sun May 17, 2009 1:05 am
SR71 wrote:There is ~20hp difference between even their own tests on a 06 and 07 RS4...
actually 349 vs 333 ~4.8%
torque (which is what is actually measured) 277 vs 270, 2.6%
both are within 5%, which is about the repeatablity to expect...
I would call the whp on this dyno for an RS4 ~ 340...
the same as Automobile measured when comparing to an R8
S2tuner
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Re: RE: Certified dyno graph:
Post by S2tuner » Sun May 17, 2009 8:19 am
ArthurPE, the Rototest is a hub dyno, not a roller dyno, so please stop talking about whp on the Rototest, as it's power at the hubs, not at the wheels+tyres.
OMG the S3 is more than overrated, it has no drivetrain losses, I didn't know that was even possible, or then Audi really give everyone a lot of BHP for free, that's nice, why are tuners still in business? I really wonder...
Anyway, what are you trying to tell us? That Audi have made a perfect engine that makes 100% of its rated horsepower, is that right?
AntoRS4
Post by AntoRS4 » Sun May 17, 2009 12:57 pm
on my dyno i see the same...
stock s3 270hp
stock rs4 from 350 to 390hp ( depends from valve deposits )
a5 3.Tdi 240hp/250hp ( same torsen as rs4 )
bmw335i 300/310hp
if the dyno has a good software and front/rear linked axles there is no way to loose measure precision, drivetrain losses are perfectly compensated.
take a look at our dynos http://www.cmdtec.com/index.asp
about sarcasm.. i prefer it to offences :wink:
Locked
Users browsing this forum: dan32v, Google [Bot], Google Adsense [Bot] and 119 guests
