Juddering from pull off full lock??
mattler
Post by mattler » Sun May 10, 2009 9:04 pm
When I pull away on full lock there is a wierd juddering/vibration??
Is this normal on an RS6, the wheels are standard but its running Bilstiens
Matty
S4WON
Post by S4WON » Sun May 10, 2009 9:19 pm
yep!..
this... http://www.rs246.com/index.php?name=PNp ... ic&t=77026
what I will say, is no, I don't have an RS6 (yet), but ive owned 3 other 4WD audis, its pretty common - don't lose sleep, but get it checked if its real bad......
mattler
Post by mattler » Sun May 10, 2009 9:39 pm
S4WON wrote:yep!..
Its not horrendous and somehow seems normal but I know the car has recently had laser 4 wheel alignment done so just thought I`d check!
ecain63
Post by ecain63 » Mon May 11, 2009 7:41 am
Its normal for permenant 4wd drive cars to have a bit of 'judder' on full lock. If its really bad then get it checked, but nothing to worry about if not. Its all to do with the wheels turning at different speeds when under full lock, causing grip issues as they fight the diffs.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
TIMSRS
Post by TIMSRS » Mon May 11, 2009 6:12 pm
Yep, mine does exactly this my s6 did the same also. i would say nothing to worry about.
bwinston
Post by bwinston » Tue Jul 28, 2009 11:01 am
my RS4 is the same, i wouldt worry.
Post by Shoppinit » Tue Jul 28, 2009 6:02 pm
Normal. There's a fairly interesting explanation on why it does this, but I can't remember what it is.
ecain63
Post by ecain63 » Tue Jul 28, 2009 7:37 pm
^^^^^ 4 wheels trying to turn at the same / similar speed when the inside wheel is almost at standstill due to full lock. This causes inside wheels to drag.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Cornishmoocher
Post by Cornishmoocher » Thu Jul 30, 2009 3:22 pm
You may also find that the front wheels are touching the arch liner, mine does this, took grizz and i about 30 mins to figure out what it was, driving back and forth on full lock. It is very common- sounds and feels like a graunching bearing.
It's all Bollox.
Users browsing this forum: srichards and 56 guests
