s5 4.2 turbo
s5 4.2 turbo
hi, just read the redline mag today, abt have developed a turbo for the s5 will that also fit the rs4 considering the engines are the same
- PetrolDave
Re: s5 4.2 turbo
I thought the S5 4.2 V8 wasn't FSI - and that it was the same engine as the S4 V8?jacksrs4 wrote:hi, just read the redline mag today, abt have developed a turbo for the s5 will that also fit the rs4 considering the engines are the same
That's not the same engine as the RS4 (40 valve not 32 valve, indirect injection not direct injection, etc.).
RE: Re: s5 4.2 turbo
I still want a turbo though.......and I thought it was a de-tuned RS4 engine with FSI
The S4 does have FSI, but its engine is far from being just a de-tuned RS4 engine...
They are totally diferent engines look on Audiworld.com for the engines.
- PetrolDave
Re: RE: Re: s5 4.2 turbo
The B8 V6 S4 certainly has FSI, the B6 V8 S4 definitely doesn't (I've owned two) and AFAIK the B7 V8 was the same engine as the B6 V8...S2tuner wrote:The S4 does have FSI, but its engine is far from being just a de-tuned RS4 engine...
Sorry crossed wires somewhere, I'm talking S5, as per the original comment, not S4 which I know are a world apart from the RS4 engine.S2tuner wrote:The S4 does have FSI, but its engine is far from being just a de-tuned RS4 engine...
The B7 S4 had the same power as the B6 but as far as I'm aware, at least some of them were FSI. Seen a few too, so not relying on second hand information herePetrolDave wrote:The B8 V6 S4 certainly has FSI, the B6 V8 S4 definitely doesn't (I've owned two) and AFAIK the B7 V8 was the same engine as the B6 V8...S2tuner wrote:The S4 does have FSI, but its engine is far from being just a de-tuned RS4 engine...
I gotcha but the S5 is still not a detuned RS4 engine.Oli wrote:Sorry crossed wires somewhere, I'm talking S5, as per the original comment, not S4 which I know are a world apart from the RS4 engine.S2tuner wrote:The S4 does have FSI, but its engine is far from being just a de-tuned RS4 engine...
- PetrolDave
To accommodate the direct injectors the FSI engines had to be changed from 5V per cylinder to 4V per cylinder, so the B6 engine is NOT the same engine as the FSI 4.2 V8.S2tuner wrote:The B7 S4 had the same power as the B6 but as far as I'm aware, at least some of them were FSI. Seen a few too, so not relying on second hand information here
Since you say you have seen some B7s with FSI, but you also say that the B7 S4 had the same power as the B6 - the ONLY way both these can be true is if the engine was changed during the life of the B7. Does ETKA support this?
I've just checked on ETKA and the cylinder heads of a 2003 B6 S4 have the part numbers 079 103 063 AS and 079 103 064 AS but a 2008 B7 S4 has two possible sets of part numbers 079 103 063 AS and 079 103 064 AS, or 079 103 903 GX and 079 103 904 GX - which implies that the B7 engine was changed during the 2008 MY.
b6 and b7 s4's are NOT fsi engines only the b8 s4 is. the s5 IS a v8 fsi (along with the q7,r8,a6 and a8) and its motor and the rs4 motor start life out on the same base block but thats where any similarities stop, from that point on there built up much differently with very different parts.
2007 rs4 mugello blue premium package, sirius, black optic grill, miltek non-res non-valved catback, milltek dp's, stasis/alcon clutch, bodymatched reflectors, tints, xenon interior bulbs, KW V3, 10mm h&r spacers, REVO flash, K&N drop in filter, euro steering wheel, jhm short throw,De-Flapped, ac glove mod, IMA multimedia adapter, h-sport sways, some alcantra on the way
- PetrolDave
Users browsing this forum: N9ATH and 59 guests
