B7 - Sorts Suspension Plus
Please can someone with experience give me the pros and cons of 'Sports Suspension Plus'. Is it too harsh?
Alastair
Alastair
RE: B7 - Sorts Suspension Plus
not for me!
I think rAudiGuy will be quite well placed to comment, he has the non sport, and has been out in mine to see what it felt like... he said there was not much in it I think...
I like the way it looks, its amazing how low it is!
do it!
do it!
if it wasnt so expensive to fit, id buy some springs and have it
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
So how expensive is it? Do Audi do it as a retrofit?
Around £1200 for parts last time i looked
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Harshness is a personal thing, the only way to be sure is to drive both set-ups and decide for yourself.
will someone take me out in the SS+ setup on the 18th April? Im interested to see the difference and then decide
No problem
Its a saloon though, so you better hold on if you used to the Avant
Re: RE: B7 - Sorts Suspension Plus
excellent, its the saloon I have!Marcus-RS4 wrote:No problemIts a saloon though, so you better hold on if you used to the Avant
- PetrolDave
Why? Do saloons have worse handling than Avants?Marcus-RS4 wrote:No problemIts a saloon though, so you better hold on if you used to the Avant
RE: Re: RE: B7 - Sorts Suspension Plus
Its the weight saving, allows you to go faster
I had my saloon on std susp for first 7000 miles.
Then swapped it for a SS+ with a car of same mileage (owned by a certain ex BTCC racer) and have doen a further 6000 miles on it.
SS+ is slightly harsher as you would expect, but by no means uncomfortable - equivalent to my previous car - a boxster S on 18"s
Pluses:
Major one is drastic reduction in body roll, which for me was the one chink in the std car's handling
10mmm lower looks better
Overall a major improvement IMHO - would not now buy one without it (I was very lucky to find someone wanting to swap the other way so cost was minimal)
Pluses:
Re: RE: Re: RE: B7 - Sorts Suspension Plus
so, just to check you changed the springs only? or are there other parts also?Adam wrote:I had my saloon on std susp for first 7000 miles.
Pluses:
RE: Re: RE: Re: RE: B7 - Sorts Suspension Plus
I'm confused (not unusual) because my car is a 2MU (as opposed to 2MC) and I get little roll.
I figure roll in general is also a function of low system pressure in the DRC (and how prevalent is that bearing in mind the long list on the other thread?) and under-inflated tyres.
I tend to run slightly higher pressures in my tyres than that specified as I prefer the "feel" of the car in this configuration.
In addition, going to SS+ will almost certainly mean that you'll never get snow-chains on the bugger...thats the main reason I never went down that route. Even on SS cars, fitting them on the rear would be asking for trouble...
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
- Winterrunner
Im pretty sure the SSP was only a Euro option? Is there a way to do the conversion on a US spec RS? Links to parts? Does it still utilize the DRC? Thanks.
