Gearbox question
Gearbox question
Hi all,
What are the symtoms of a gearbox problem on a 2002 rs6 with 65,000 on the clock?
I cold be wrong, but it seems that when it's cold, the revs in top gear are higher than normal for a given speed for the 1st minute or so, eg normaly 60=2000, but more like 60=2600 for the first minute or so, after that smooth and very very positive selection.
Not sure i really want to hear the answer to this...lol
Paul.
Paul.
RE: Gearbox question
I've never had gearbox problems, but that would sound like the lock-up clutches slipping. From what I've seen, the recommended course of action would be to change the ATF and strainer and hope the problem goes away...
From what I've seen, other symptoms include getting a whallop in the back when changing gear under load.
Whining generally means low ATF level (on most autoboxes).
RE: Thanks
I don't know enough about it. Perhaps someone else could give you a better answer. I'll be changing the ATF and filter in my box soon as a precautionary measure. Perhaps you should do the same?
RE: Thanks
I would change the fluid and see how it goes (unless this has been done recently?), but make sure it is done correctly (up to temp, checked with VCDS etc). Take to someone who knows how to work on the RS6
When my gearbox went (usual slip and BANG followed by limp mode and then no torque to road) first thing Audi did was replace the fluid - like that was going to make a difference when it wouldn't go anywhere. Audi seems to think that this is a lifetime fluid - I had burnt ATF fluid at 37,000 miles and will be replacing mine every 20k.
Hope this helps.
Grant
Hope this helps.
Grant
Re: Gearbox question
Wouldn't this be the lock-up clutches not locking up? But might this be normal behaviour - maybe the computer is deliberately not locking the box until it's up to temperature?raceman wrote: I cold be wrong, but it seems that when it's cold, the revs in top gear are higher than normal for a given speed for the 1st minute or so, eg normaly 60=2000, but more like 60=2600 for the first minute or so, after that smooth and very very positive selection.
I've never experienced these symptoms (or never noticed them at least) but then I can't really get above 30 without getting out of town, at which point everything is well up to temperature. I'll try and check next time I start from cold in the country (don't hold your breath).
- andrewwilson8
Re: RE: Thanks
I took mine in to have coilovers fitted and for a full service. i had experienceed the symptoms described above a couple of times so asked for the gearbox fluid to be changed. Unfortunately the guy that did it did not have a clue how to fill the fluid up properly and let me take it 100miles home with only half the fluid needed. This caused all the friction components of the box to overheat severely and burn out. it is now back at the garage who have sent the box away for a possible re-furb.GardinerG wrote:I would change the fluid and see how it goes (unless this has been done recently?), but make sure it is done correctly (up to temp, checked with VCDS etc). Take to someone who knows how to work on the RS6
Hope this helps.
Grant
Before i sent it back to him i had audi look at it to give me an independent assessment. they told me the box would need replacing and quoted me £5350!!
I strongly recommend you get the box checked by someone who knows what they are doing, i.e Audi or one of the specialists you find on here. It will be worth it in the long run. I have read that a proper ATF change can cure mild syptoms like you describe, like i had hoped to do myself. so good luck!
andy
RE: Re: RE: Thanks
You should be able to get an exchange box for around the £2000 mark I think
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!!
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
**** SOLD!!!
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Unit 20 TCU remap
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
Tesla Model X 60D
Make sure they change the filter & them carry out the refill in the correct manner.
Unit 20
0151 3366888
0151 3366888
Anyone got any recomendations for a specialist anywhere near kent?
Nice green 52 plate RS6
1974 Triumph Stag
1994 Landrover 110 CSW
Volvo V70
Pro photographer, weddings, parties, cars, track days, portraits or anything photograhic catered for, event Photography a specialty.
www.medwaystudio.co.uk
paul@medwaystudio.co.uk
1974 Triumph Stag
Volvo V70
Users browsing this forum: Google [Bot] and 57 guests
