audi tyre homologation
- Spacecowboy
Dan, take a look on this page:
http://www.carbibles.com/tyre_bible_pg2.html
Scroll down about a third of the way down to the 'Tyre size calculator'
If you put in there on the left where it says 'current wheel/tyre' 255/35/19 and click calculate. Then on the right where it says 'new wheel/tyre' enter 275/30/19 and click calculate. Then click 'calculate difference' and below will be a graphic showing the circumference difference between the two (current tyre in grey and new tyre in red outline). You will see from that, that the 275 is actually smaller! This compensates for the increase in width and is probably why my tyres haven't rubbed.
I still cannot however explain why yours have rubbed, sorry!
- Spacecowboy
Whilst I understand everything that's been said here two things occur to me.
1) If someone fitted tyres to my car that rubbed I'd be back there immediately, I wouldnt have even gone home!
2) Just because you ordered that particular make and size doesnt matter, your tyre place has a responsibility to you to ensure the car is safe! Unless they told you it was rubbing and was unsafe and you still took it?
This is very true!355marcus wrote:..your tyre place has a responsibility to you to ensure the car is safe!
I forgot to mention that when my Vreds were fitted, although the 2 fitters didn't test-drive the car, they did at least check for rubbing while the car was up. I think that I would be having words truth be told.
- Top Gear
I once had a set of the old style Eagles fitted on my old 2.4v6 A4 avnt, the fitter had real problems balancing the tyres, but eventually he said he done it. paid up mand left. when driving home, if i got up to orover 90mph, the car shook itself so badly that you coyuld not drive it! I went back to the tyre fitter and told him,and he said- " yeah it thought that might happen, i didnt think id got it right!!". I told him to stick the old tyres back on and that i would be going elsewhere. he said he wouldn't. so i phoned my card people, explained whet had happened, they spoke to the guy and i got the tyres for free. I went to another fitter up the road who re fitted them tested the car and al was fine! Moral- always take the fitter out and scare him shitless- just to show him how important it is for your tyres to be fitted properly- i still use the second fitter, they look forward to having a blast in the beastie!
It's all Bollox.
- Spacecowboy
I thought, that it rubs at the outside, because my car is low...that was a big misstake by me355marcus wrote:Whilst I understand everything that's been said here two things occur to me.
now I get the conti sport contact and there is many more space !!!
the dunlops are 270mm....
- Spacecowboy
- Spacecowboy
ok now I'm dying to hear. I wanna go for 275s but now theres all this talk of 'rubbage' I'm paranoid now. I cant afford to shell out 800 quid on a brand new set and find out theyre fouling all over the place.
Any concensus which 275s fit and which dont? I will soon be making the change to H&Rs but currently running on DRC...
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
