Fuel adatives....
Good question. Its not just direct injection thats the problem. Its direct injected engines that volatize (consume) high quantities of oil. If other direct injected engines are volatizing small amounts of oil, there is much less oil in the crankcase air stream and much less oil that can be deposited on the valves. The RS4 engine consumes a large amount of oil - a liter in 2000-6000 miles is typical. I don't think the oil consumption is a big surprise to Audi, but maybe the intake deposit problem is.PetrolDave wrote:Mitsubishi had GDI long before Audi has FSI - is there any evidence of this sort of problem on their engines? If not, why not - what's different about their configuration?
- PetrolDave
Since all petrol engines are going to be direct injection in a few years (to cut emissions) - the latest Porsche engines are direct injection - then we're stuffed!Oli wrote:Yes GDI had loads of problems, we had a couple in, that were all gummed up
What we need is some kind of cleaner that we can spray into the area between the air cleaner and the valves...
I don't for a second think that Audi don't know about the issue.
Its only because we're enthusiasts that owners are opening up their manifold and having a look in there anyway...when else would the average owner ever expect to see the inside of their manifold?
I'm staggered at that kind of build up though after that mileage.
What about an (m)ethanol spray down the intake?
(Disclaimer: I know nothing about (m)ethanol!)
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
Re: RE: Fueladditive
I'm having a bit of work done with MRC so they will be investigating & sorting if necessary while they have the car.Marcus-RS4 wrote:Who are you getting to clean them pippyrips? (out of interest)
In talking this problem through with them, a menthanol injector into the manifold is a possible option but a pretty expensive one.
The plan is to monitor buildup over 3000-4000 miles then make a judgement from there.
RE: Re: RE: Fueladditive
Keep me / us posted, I may well be tempted based on your findings!
I think the simple fix would be for Audi to inform all the dealers that intake valve buildup will be possible in any FSI they sell, particularily the 4.2FSI. Each vehicle should be allowed one valve inspection at the minimum, clean them if necessary and plan on regular cleaning afterward (its a dream, I know). If the buildup was controlled in this fashion, there would probably be much fewer engine problems for everybody. Also, once the dealers are aware of this, they can DISPENSE WITH the typical BS that makes the buildup somehow associated with the owner, such as "How do you drive the car?", or "Do you go for short trips?". Those variables are insignificant when you consider how bad the build-up is regardless of how the car is driven.
Will do
Additives
Have a read of the following response from an enquiry to Wynn Products.
I've never been a fan of additives but perhaps these are worth a try.
Dear Sir,
We developed some years ago a dual product for Direct petrol injection engines
a) A fuel additive to clean the injectors, and have a keep cleaning action on the inlet by product returned to the inlet by mean of the EGR system.
b) A spray to clean the air intake system, inlet valves, EGR valve. This needs to be sprayed in the inlet, with running engine (see attached technical data sheet)
I think in your case certainly product (b) is very advisable. For a Total and perfect cleaning it can be used together with (a).
Mitsubishi for example is executing the dual treatment in Belgium at each 15 000 km service interval.
We would appreciate your feedback on our technical assistance. Please reply to this e-mail with the table filled out :
(indicate “Xâ€
Dear Sir,
(indicate “Xâ€
RS4 B7 Phantom Black
RE: Additives
Thanks, looks very interesting .. wonder what the supply is like ... Halfrauds anyone ?? LOL
RS4 Avant - Sold Aug 2009
RE: Additives
Where the hell do you buy it from though? Its the first Google search that hasnt thrown up anything, ever!! lol
RE: Additives
you didn't search properly! i got lucky first time
will keep searching, though in one link it said 'trade only'
http://www.wynns.be/product.aspx?nav=2& ... 23079&l=EN
http://www.wynns.be/news.aspx?l=EN&isec ... icleid=282
http://www.volvoforums.org.uk/showthread.php?p=433785
RE: Additives
ok - i've mailed Wynn's uk customer services asking for a supplier and price for the two products & have their phone number. Should hopefully have some answers tomorrow
Group buy anyone
Group buy anyone
Users browsing this forum: No registered users and 98 guests
