gearbox remap question
S2tuner
Trader (Expired)
Re: gearbox remap question
Post by S2tuner » Fri Feb 27, 2009 11:20 am
SteveG wrote:
S2tuner wrote:
SteveG wrote:Does anyone know the answer to this question ?:
If you have your gearbox remapped by someone like MRC, then does the gearbox ecu have to be taken out and re-soldered back on ? or is the process the same as simply plugging into the main ECU port? (no removal and then soldering involved)
Steve G
No one in the world can flash a tiptronic ECU through OBD2 as far as I'm aware, I don't even think the ECU supports it...
As for how visible it is, I can solder so no one can see that the chip has been soldered before or not.
I didn't mean remapping the gearbox via the OBD2 port, I was asking if it was a similar process (via a similar plug in cable method) :lol:
Unfortunately or fortunately the only way the gearbox ECU can only be done via the classical chip tuning way, which is chip desoldered, read, programmed with a modified program and soldered back on the ECU. Just as well it's done this way, so "OBD2 only" tuners can't do anything about any tiptronic at all.
RichRS6
RE: Re: gearbox remap question
Post by RichRS6 » Fri Feb 27, 2009 12:32 pm
Just out of interest.......
How much does the gearbox remapping cost on top of the Stage 2 + engine remap if I were to have the whole lot done at the same time ?
03 Mugello Blue Avant, Silver Leather, Carbon Fibre, Alcantara Headlining, MFSW, Electric folding Mirrors. H&R Coilovers, Hotchkis ARB's, Res Miltek, APR R1's, ITG Filters, RNS-E, OEM Bluetooth, Digital Freeview and Headrest Monitors, Aero Wipers, Rear Aero Wiper and R/H parking Mod, Rear Fog mod, Valentine 1.
355marcus
RE: Re: RE: Re: gearbox remap question
Post by 355marcus » Sun Mar 01, 2009 3:09 am
Quick question from a Newbie! What is the Stage 2 Gearbox map? Does that mean you also do a Stage 1, or that this is your second or evolved map if you see what i mean!
355marcus
Re: RE: Re: RE: Re: gearbox remap question
Post by 355marcus » Mon Mar 09, 2009 11:59 am
355marcus wrote:Quick question from a Newbie! What is the Stage 2 Gearbox map? Does that mean you also do a Stage 1, or that this is your second or evolved map if you see what i mean!
Dammit Janet I know I'm newish but I had hoped for a bigger clue than that!! :D
S2tuner
Trader (Expired)
RE: Re: RE: Re: RE: Re: gearbox remap question
Post by S2tuner » Mon Mar 09, 2009 12:02 pm
Sorry Marcus, I missed your question... for tiptronic cars, the stage 1 simply involves raising the torque limiter so the gearbox doesn't hunt between 5th/4th gears, it is mandatory with a remap on any tiptronic vehicle. The stage 2 is more evolved with improved shift patterns, higher shift points, and allowing you to go into 5th gear at 30 mph.
hope this helps,
Mihnea
Users browsing this forum: asgor, srichards and 57 guests
