RS4 Engine...?
RS4 Engine...?
I have a mate who is torn between the S4 and RS4. He wants the RS4 power but will not go past Tiptronic. Has anyone thought about transplanting an RS4 engine into the S4?
I suppose MRC could Map the box to cope with the increased revs.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: RS4 Engine...?
What about a s4 with a super charger ..... Much more power than a rs4..
Unit 20
0151 3366888
0151 3366888
- BlingBling
RE: RS4 Engine...?
Not 100% it will that straight forward. Although they are very similar engines the RS4 block sits higher with respect to the S4 so I assume it is installed lower in the RS4. Also the ECU are completely different. 2x in the RS4, 1x in the S4 so I am not sure if mapping the box is an option. MRC would know for sure.
If he is adamant on a Tip get him to buy the S4, replace the precats with piggies, ECU map, install the RS4 RARB and bobs your uncle. Performance wise it will be below the RS4 but is will be much better than a stock S4.
RE: RS4 Engine...?
SC is an option too...I suppose whatever is cheaper. MRC talking about a 2.7 engine transplant, the downside is that we getting away from the V8. I know the 2.7 is glorious but the V8 noise is in a different league.....
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: RS4 Engine...?
I think the effort of putting an RS4 engine into an S4 with tiptronic transmission is really not worth the extra 70HP IMHO, suspect the result would only be as quick as a manual S4. If the transmission is the over-riding priority then go for the S4 with mods described above, the S4 handling is not as sharp as the RS so the solution seems to be the best option in terms of driver experience.
I would also add the S4 is no slouch itself, from a rolling start against an RS4 mine did not disgrace itself
RE: RS4 Engine...?
how much is the SC kit for the S4?
B5 RS4 MTM 420 bhp
Misano RS4 with some MTM magic!!
Re: RE: RS4 Engine...?
Much more than a B6S4 is worth.PaulyS4 wrote:how much is the SC kit for the S4?
Stage 3 AMD remap and a miltek is 390+ so it won't be million miles away.
Around the ring a B6S4 Avant is less than 2 seconds a mile behind the B7 RS4 so if you're on public roads it's not going to matter anyway. You've only got to be a slightly better driver, and and he's going nowhere.
Last one dead's a sissy.
About £11,500!!!PaulyS4 wrote:how much is the SC kit for the S4?
The PES supercharger is 6,495 Dollars. Web site is http://www.pes-tuning.com/PaulyS4 wrote:how much is the SC kit for the S4?
There's quite a few S4's that have been done and one of the first development vehicles was a 2005 S4 B6 Cab, so it's well tested.
- verysideways
- 1st Gear
RE: Re: RE: RS4 Engine...?
Hang on - i thought the B6 S4 usually produces about the sort of power that's expected, round 330/340bhp, whereas a lot of B7 RS4s produce less power than expected, around 360/370bhp.
So really what we're talking about, potentially, is only 35hp or thereabouts?
2003 B6 S4 Avant 'chase car'
Petrolhead Tours Driving Holidays
Does anyone have any experience of the PES kit? Looks good :p
