porsche brakes
2.7 V6 30v biturbo - 380 bhp
m888rsy
porsche brakes
Post by m888rsy » Sat Feb 14, 2009 10:34 pm
hi
has anybody upgraded to porsche brakes?where will i get mounting brackets for the calipers?will they run on standard b5 discs or will i have to change them?if so which porsche calipers are suitable?
thanks mike
frazered
RE: porsche brakes
Post by frazered » Sun Feb 15, 2009 12:51 am
jimbo was running cayenne 6 pots with b5 rs4 discs turned down to 350mm
believe they are bolt on, but heard grizz can arrange any additional carrier mountings that may be required
most are moving to b7 rs4 calipers which are about the same cost as the cayenne ones (both second hand)
davs4
RE: porsche brakes
Post by davs4 » Sun Feb 15, 2009 10:43 am
I thought they were lug mounted other than radial, therefore no bracket is required.
davs4
RE: porsche brakes
Post by davs4 » Sun Feb 15, 2009 10:59 am
I have borrowed a guide on installation from ECStuning website which shows the attachment of the caliper...
http://www.ecstuning.com/stage/support/ ... tage4.html
Durit
RE: porsche brakes
Post by Durit » Thu Feb 19, 2009 11:41 pm
996 turbo/996GT3 mk1 4pots calipers with 380 rotors
or 996 GT2/GT3 mk2 6 pots calipers with 380 rotors but pads need to be machined
you can get rotors and brackets from Movit, can use Brembo rotor too but offset need to be modified
RS4 B7 8 pots calipers with RS4 B7 rotors ... plug'n play
RS4 B7 8 pots calipers with 380 Brembo rotors (bracket needed)
PS got 1 set of movit 380 rotors 4 sale
RS4 mtm 460 "safety car", Milltek, Koni, Mov'it 6/380-4/322, teamDynamics wheels ------- S6 plus, mtm, H&R, Koni
I'm french (nobody's perfect) sorry for my bad English!
MK4ASH
RE: porsche brakes
Post by MK4ASH » Fri Feb 20, 2009 1:02 am
I've just fitted PCCB's all round on mine and MOVIT wouldnt sell me the brackets seperately so had to have my own machined up locally. I'm running B7 discs all round and did have to have the pads machined down! It ended up being a real mission but they work amazingly now and the yellow calipers look great behind the standard 18's.
If it aint broke then dont try to fix it!
B5 RS4
MRC 420+Expired Precats
PCCB Calipers x4-B7 Discs x4
R8 Handbrake Calipers
Milltek
710N's
Durit
Re: RE: porsche brakes
Post by Durit » Fri Feb 20, 2009 10:38 am
MK4ASH wrote:I've just fitted PCCB's all round
can we have a pict?
how are mounted the rear brakes and the hand brake caliper, please?
fabriziors4
RE: Re: RE: porsche brakes
Post by fabriziors4 » Fri Feb 20, 2009 6:30 pm
Hallo durit,can you send me a picture about movit brakes??380x32...thank's a lot ilfabs@yahoo.it :D :D :jump: :kissmyrings: :kissmyrings: :kissmyrings:
MK4ASH
Post by MK4ASH » Sat Feb 21, 2009 10:51 am
@ Durit Fronts are mounted using adaptors like AP's use etc etc so they were easy. The rears were a pain. I pressed out the rear bearing and made a plate out of 10 mm steel that holds both the main 4 pot and the R8 handbrake calipers.
I had the rear struts machined to accept the plate and the used the existing holes to mount the plate.
The dust sheild mounts were re-drilled to make use of them too. I'll put some pics up when i get 5 mins and have cleaned everything up.
B5 RS4
Milltek
710N's
Durit
Re: RE: Re: RE: porsche brakes
Post by Durit » Thu Feb 26, 2009 7:18 pm
MK4ASH wrote:made a plate out of 10 mm steel that holds both the main 4 pot and the R8 handbrake calipers.
ok
brembo sell similar system
Users browsing this forum: Google [Bot] and 37 guests
