My friend want to do his RS4 liitle more powerfull )
He get RS4/RS6 turbos, FMIC, Wagner Tuning exhaust manifold, Milltek exhaust from turbos, 255 l/h fuel pump and bigger injektors.
But tuningman said this set will be around 500 h.p.
What we want to do to get 550 or more h.p. ?
550 h.p. or more
RE: 550 h.p. or more
RS6 turbos
(or a Garrett GT28 setup...)
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
Re: RE: 550 h.p. or more
What about exhaust manifolds for it ? Flanges ?andream88 wrote:RS6 turbos
It will be custom work or bolt-on kit ?
RE: Re: RE: 550 h.p. or more
You have to modify both to install them as bolt-on kit:
RS6:
already modified by JHM ---->>> http://www.jhmotorsports.com/shop/catal ... ucts_id=18
GT28:
http://audisrs.com/about2383.html
RS6:
GT28:
Rs4 b5 06/2001
Thanks, thats great info !
And another couple of question )
1)For more then 500 h.p. we need to use forged set of pistons, rods or just head gasket compression dropping ? When is rubikon ? ))
2) In Moscow i dont hear anything about tuning camshafts for RS4. OEMs is so good and we dont need to replace it ?
What about manufactures who produce aftermarket camshafts ?
