I'm planning on remapping my ECU and part of the process entails disconnecting the battery. Unfortunately I don't have my radio PIN. The manual says that in some models it shouldn't be a problem if the unit is still in the same car so therefore it can learn w/c putting back the PIN. Is this right?
Thanks folks
Do I need my radio PIN if I disconnect te battery for B7 RS4
RE: Do I need my radio PIN if I disconnect te battery for B7
That's correct. You only need the pin if the RSN-E unit is out of the car or disconnected from wiring loom. I found this out when I was doing the video-in-motion hack.
2007 RS4 B7 - Phantom black saloon
When I added the Bluetooth module, I disconnect the RSN-E and it did not need a pin when reconnected.
RS4 Avant - Sold Aug 2009
You do not need the pin to reconnect it even if you completely take it out of the car! it's coded to the car so knows it is the right unit for the car.
Jim
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
- PetrolDave
You don't need the PIN unless you do something like the VIM hack which "messes up" the non-volatile memory in the RNS-E.
