Dead speedo advice required
2.2 I5 20v turbo - 315 bhp
RS2_freak
Post by RS2_freak » Mon Feb 09, 2009 3:13 pm
My speedo has died. No warning - it simply stopped working.
I've replaced the sensor 012409191D (£16) to no avail. Needle has twitched a couple of times but never fully engaged again.
From a couple of other web sources it seems the drive gear that the sensor slots into may have gone. This is part 012409187C (about £10).
I've also been told it might be the speedo head, which costs closer to £200.
Any one else experienced this or able to offer advice as to solving the issue?
A lotta people go through life doing things badly. Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.
ChrisS2
RE: Dead speedo advice required
Post by ChrisS2 » Wed Feb 11, 2009 12:18 am
Speedo heads do go but i'd be more inclined to investigate the drive gear first. If the needle twitches when your driving, try tapping the top of the instrument binicle to see if that helps. Also, make sure the dials aren't peeling round the needles, more common on S2's, especially around the rev counter.
RS2_freak
Post by RS2_freak » Wed Feb 11, 2009 11:51 am
Many thanks. Will try replacing the drive unit first. There's no peeling around the needle and it literally was working fine when I drove it one night, then wasn't working in to morning.
I had one motorway journey when came back to life by twitching a little (needle didn't rise much), but then this didn't happen again after I'd stopped the car and restarted again. Will give it a bit of a tap to see if the old percussive maintenance works!
Cheers!
AlWyn
Post by AlWyn » Wed Feb 11, 2009 1:10 pm
My old RS2s speedo randomly stoped a couple of times... it worked again when i pushed and held in the trip reset counter hth.
Users browsing this forum: No registered users and 31 guests
