hesitation at high RPM
almeister09
Post by almeister09 » Mon Feb 09, 2009 9:23 pm
HELP,
I have an 06 plate RS4,@6,000 rpm there is splutter/hesitation for 2-4 seconds.Taken to dealer who cannot fault,no faults in any system,the ECU software version is the latest 090,ive been asked what octane i,m running on,which of course the dearest 98ron, anybody ANY ideas,this is an annoying problem.
I feel like i,m being fobbed off!!!!!!
pippyrips
RE: hesitation at high RPM
Post by pippyrips » Mon Feb 09, 2009 9:44 pm
2-4 seconds?! that's one hell of a splutter! Has the tech actually experienced the symptoms first hand? It could be a number of things but for starters look at the plugs...
Marcus-RS4
Post by Marcus-RS4 » Mon Feb 09, 2009 9:46 pm
plugs or coil packs failing? Anything coming up on VAG-COM?
W8PMC
Post by W8PMC » Tue Feb 10, 2009 9:39 am
Is the car fully warmed up??
The DIS displays to keep revs below 6000rpm until the engine is at normal operating temp & depending on driving style/roads it can take a good few miles before reaching the correct temp.
The car has a temporary limiter at 6K RPM until correct engine temp is achieved. I've been a little keen before now & hit that limiter as i'd assumed the engine was at the correct temp, but was obviously a little early.
Other than that i've never heard of such a stutter.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
tartan_rob
Post by tartan_rob » Tue Feb 10, 2009 10:09 am
Is this on part throttle or WOT?
2017 Kawasaki Z1000
2014 RS6
2014 S1
almeister09
Post by almeister09 » Tue Feb 10, 2009 10:37 am
car is warmed up,can replicate at about 5,000 rpm more or less WOT,spark plugs have been replaced and coil packs are all good.Dealer says no faults in their 5052B diag equipment.
Does feel like a fuel restriction but i am no nearer.
david7m
Post by david7m » Tue Feb 10, 2009 11:01 am
Bad batch of fuel?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
Marcus-RS4
Post by Marcus-RS4 » Tue Feb 10, 2009 11:09 am
W8PMC wrote:Is the car fully warmed up??
Is 6k cold limit due to your remap? Standard is 7k?
rAudiguy
Post by rAudiguy » Tue Feb 10, 2009 11:47 am
even if you have the rev limmieted changed under a remap to 4.5k 5k 6k whatever your choice the display will still read 7k because this can't be changed.
I think just a typo from Paul re the 6k.
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
W8PMC
Post by W8PMC » Tue Feb 10, 2009 1:12 pm
My bad. :oops:
Did mean 7K, only limiter difference with the map is an extra 300ish RPM at the top end.
Read the O/P 6K then thought i've seen the number 6 (limiter vanishes at 60 degrees) so typed crap :oops:
Paul
PetrolDave
Post by PetrolDave » Tue Feb 10, 2009 1:24 pm
W8PMC wrote:The DIS displays to keep revs below 6000rpm until the engine is at normal operating temp
It's 7000rpm (unless you've had it changed during a remap), and it's not advisory - the limiter is at 7000rpm until the oil temperature reaches 60 Celsius when it is moved to 8250rpm (unless you've had that changed during a remap).
david7m
Post by david7m » Tue Feb 10, 2009 1:34 pm
WOW, even 7k when coldish is a lot :shock:
almeister09
Post by almeister09 » Tue Feb 10, 2009 1:35 pm
Hot or cold this happens so i can rule out oil temperature, As stated i only use the high octane fuel,i have had this problem for some time..
PetrolDave
Post by PetrolDave » Tue Feb 10, 2009 2:00 pm
almeister09 wrote:Hot or cold this happens so i can rule out oil temperature, As stated i only use the high octane fuel,i have had this problem for some time..
Coil packs have to be the number 1 suspect, but VAG-COM would usually show fault codes if it's them.
So maybe the plugs need changing? Do you do a lot of town driving and/or low revs?
NGS521
Post by NGS521 » Tue Feb 10, 2009 5:11 pm
Wouldn't the coil packs have forced the car into 'safe mode'?
The Black Panther
