hesitation at high RPM
HELP,
I have an 06 plate RS4,@6,000 rpm there is splutter/hesitation for 2-4 seconds.Taken to dealer who cannot fault,no faults in any system,the ECU software version is the latest 090,ive been asked what octane i,m running on,which of course the dearest 98ron, anybody ANY ideas,this is an annoying problem.
I feel like i,m being fobbed off!!!!!!
RE: hesitation at high RPM
2-4 seconds?! that's one hell of a splutter! Has the tech actually experienced the symptoms first hand? It could be a number of things but for starters look at the plugs...
plugs or coil packs failing? Anything coming up on VAG-COM?
Is the car fully warmed up??
The DIS displays to keep revs below 6000rpm until the engine is at normal operating temp & depending on driving style/roads it can take a good few miles before reaching the correct temp.
The car has a temporary limiter at 6K RPM until correct engine temp is achieved. I've been a little keen before now & hit that limiter as i'd assumed the engine was at the correct temp, but was obviously a little early.
Other than that i've never heard of such a stutter.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
Is 6k cold limit due to your remap? Standard is 7k?W8PMC wrote:Is the car fully warmed up??
My bad.
Did mean 7K, only limiter difference with the map is an extra 300ish RPM at the top end.
Read the O/P 6K then thought i've seen the number 6 (limiter vanishes at 60 degrees) so typed crap
Paul
- PetrolDave
It's 7000rpm (unless you've had it changed during a remap), and it's not advisory - the limiter is at 7000rpm until the oil temperature reaches 60 Celsius when it is moved to 8250rpm (unless you've had that changed during a remap).W8PMC wrote:The DIS displays to keep revs below 6000rpm until the engine is at normal operating temp
- PetrolDave
Coil packs have to be the number 1 suspect, but VAG-COM would usually show fault codes if it's them.almeister09 wrote:Hot or cold this happens so i can rule out oil temperature, As stated i only use the high octane fuel,i have had this problem for some time..
So maybe the plugs need changing? Do you do a lot of town driving and/or low revs?
Users browsing this forum: Google [Bot] and 101 guests
