Drivers Side Door Mirror
RS4MAD
Post by RS4MAD » Tue Jan 06, 2009 9:01 pm
Hi All
Anyone know where I can get one of these from that won't break the bank! Some burk hit mine today and drove off - polite! :x
Anyone got any ideas how much I might be looking at?
Cheers Rich
rAudiguy
RE: Drivers Side Door Mirror
Post by rAudiguy » Tue Jan 06, 2009 9:29 pm
if it's the glass your after try here. http://www.ecstuning.com/stage/edpd/pag ... ry=Mirrors
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
RS4MAD
Post by RS4MAD » Tue Jan 06, 2009 9:56 pm
The glass is ok,it's the surround that's gone
Oli
Post by Oli » Tue Jan 06, 2009 10:47 pm
140 squid + VAT from Audi - Total rip off for a plastic cover, thats painted.
At least the mirrors on my 8P S3 were actually alloy
It just doesn't make sense alloy on a £26k car, and plastic 'alloy' lookalike on a £50k motor
APM
Post by APM » Tue Jan 06, 2009 11:23 pm
have a look on the for sale site,theres a b7rs4 being broken for spares!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jezzer
Post by Jezzer » Wed Jan 07, 2009 2:21 pm
How easy are the mirror surrounds to take off? Would you need to take off from the inside of the door by removing some trim?
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
Oli
Post by Oli » Wed Jan 07, 2009 7:58 pm
They come off fairly easily - Pull the small triangular trim off the inside of the door - there are two screws underneath. Prise the mirroe glass off gently, which reveals two or three screws that hold the assembly onto the casing, remove these and the motor assembly, unplug theelectrics. This then reveals two screws that hold the retainer on - easy as that
gmk666
Post by gmk666 » Wed Jan 07, 2009 9:00 pm
Nick one off a chavved-up Corsa?
RS4MAD
Post by RS4MAD » Thu Jan 08, 2009 8:45 pm
OliH wrote:They come off fairly easily - Pull the small triangular trim off the inside of the door - there are two screws underneath. Prise the mirroe glass off gently, which reveals two or three screws that hold the assembly onto the casing, remove these and the motor assembly, unplug theelectrics. This then reveals two screws that hold the retainer on - easy as that
Hi,
got a mirror from a salvage yard today £185 (bargain), does the inside triangular piece need to be pulled from a particular side and do I need a screw driver to prise it off ?
thanks Rich. :?
Jezzer
Post by Jezzer » Thu Jan 08, 2009 9:38 pm
Hi,
thanks Rich. :?
Isn't that more than a dealer would charge you then? earlier someone said £140 + vat - £161
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Jan 08, 2009 9:56 pm
I think it's £140 for just the cover (backing), whereas he got a complete mirror for £185.....or at least I hope!
Virdee Autos ~ 07950-526592
Oli
Post by Oli » Thu Jan 08, 2009 10:53 pm
Just use a very small screwdriver, or you might be able to lever it with your fingers
RS4MAD
Post by RS4MAD » Thu Jan 08, 2009 10:59 pm
Jezzer wrote:
Hi,
thanks Rich. :?
Audi quoted £420+vat for the whole unit and then £92 an hour fitting!!!!!!!!!!!!!!! :shock:
Dom81
Post by Dom81 » Fri Jan 09, 2009 9:28 am
RS4MAD wrote:Audi quoted £420+vat for the whole unit and then £92 an hour fitting!!!!!!!!!!!!!!! :shock:
Sounds about right - replacing two nicked mirrors on my S4 was over £1200!
Thankfully it was a company car...
2007 Daytona RS4 Avant
DrNick
Post by DrNick » Mon Jan 12, 2009 11:50 pm
Exactley the same problem happened to me. Searched high and low to see if anyone sold the mirrors on the web but to no avail.
Was quoted £474 incl VAT fitted and colour coded by Audi.
Ended up paying £260 inclusive of VAT and fitting in the end as was able to use the original electrics/heater, so only needed shell and mirror.
Good luck
