Need more power
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
matias
Need more power
Post by matias » Wed Dec 31, 2008 4:24 pm
I am having about 450 hp, but more need more :?
Should I go for a wather/methanol kit or some AWE intercooler?
At the moment I am having some RS4 intercooler.
dazzer
Re: Need more power
Post by dazzer » Wed Dec 31, 2008 6:16 pm
matias wrote:I am having about 450 hp, but more need more :?
Don't bother spending all the money required to buy the AWE SMIC. They are a lot of money for relatively, if any gains. I am sure there are better ICs on the market for less outlay.
Nige_RS4
RE: Re: Need more power
Post by Nige_RS4 » Wed Dec 31, 2008 7:27 pm
Probably a good idea to post the current spec of your car so ppl can see what you've got and where to spend your money for the biggest returns.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
matias
Re: RE: Re: Need more power
Post by matias » Thu Jan 01, 2009 7:51 am
Nige_RS4 wrote:Probably a good idea to post the current spec of your car so ppl can see what you've got and where to spend your money for the biggest returns.
I can try Nige..
2,8 NA heads
Coated and reworked manifold
RS4/RS6 hybrid turbo
All intake is RS4
RS4 injectores
RS4 intercooler
Complete de-catted RS4 exhaust system
Remap to 1,45 bar.
My next step would be some down pipes with 400 cell sportscat
3" Milltek system..
THEN I was thinking of the wather/Methanol system from VAST, and a new re-map to about 1,5 bar..Or the bigger SMIC from AWE?????
Happy new year
dazzer
RE: Re: RE: Re: Need more power
Post by dazzer » Thu Jan 01, 2009 1:13 pm
do you have a LWFW?
thought you would be on bigger injectors already. what fuel pump do you have?
As for the down pipes do you mean 100 cell cats - a good idea.
matias
Re: RE: Re: RE: Re: Need more power
Post by matias » Thu Jan 01, 2009 1:45 pm
dazzer wrote:do you have a LWFW?
LWFW? Sorry but what is that.
I am running with a RS4 fuel pump.
For the down pipes I mean 400 cell sportscat, so I can pass the MOT here in Denmark.
dazzer
Post by dazzer » Thu Jan 01, 2009 3:00 pm
LWFW - Lightweight Flywheel.
Emmissions are much stricter in Denmark then? What about a set of 'test pipes' that you can swap over after the MOT :wink:
Not sure how much improvement from the flow you will get with the proposed downpipes as the S4 is also 400CPI anyway. Surely they have RS4s in Denmark which pass the emmissions in which case get some RS4 downpipes which are 200CPI. Have you got rid of the precats?
I am not sure what the limit is for the RS4 pump but you need some overhead for safety.
matias
RE: Re: RE: Re: RE: Re: Need more power
Post by matias » Thu Jan 01, 2009 3:21 pm
I do have the RS4 downpipes (precats) on the car now, together with OEM RS4 system..
No I dont have LWFW..
dazzer
Re: RE: Re: RE: Re: RE: Re: Need more power
Post by dazzer » Thu Jan 01, 2009 3:30 pm
matias wrote:I do have the RS4 downpipes (precats) on the car now, together with OEM RS4 system..
So you don't need to move to 400 cpi sports cats. Are you sure you can't run with 100cpi sports cats. Get rid of precats.
I have the AWE SMIC and don't think they are worth the money.
S4
RE: Re: RE: Re: RE: Re: RE: Re: Need more power
Post by S4 » Thu Jan 01, 2009 10:47 pm
if you have rs4 downpipes you already have 200 cel cats? who mapped the car.? cheapest way would be a front mount cooler. like this. http://cgi.ebay.com/ebaymotors/CXRacing ... ccessories a bit of work and you can hide it behind the bumper.
Darren
matias
Post by matias » Fri Jan 02, 2009 6:22 am
Okay I then have 200 cell cats.. But that is OEM cats.. Wouldent I get some better flow with 400 cell sportscat?
It is a Danish company who mapped the car, and some of the best.
Would I get the best power gain from a wather/methanol kit, and a complete Milltek system, instead of FMIC and Milltek system?
okkim
Post by okkim » Fri Jan 02, 2009 8:00 am
Remove the precats and change the main cats to 100 cell free flow versions. At least in Finland those will pass the MOT. Or if you are "afraid" of the emissions, use these 200 cell cats: http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... 0020368599
I have 100 cell free flow cats and the car passes the MOT without problems. (http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... 0020368592)
matias
Re: RE: Re: RE: Re: RE: Re: RE: Re: Need more power
Post by matias » Fri Jan 02, 2009 9:45 am
okkim wrote:Remove the precats and change the main cats to 100 cell free flow versions. At least in Finland those will pass the MOT. Or if you are "afraid" of the emissions, use these 200 cell cats: http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... 0020368599
The cat in the link is WERRY cheap, so think I will go for the 200cell :wink: ..Thanks Okkim
Nige_RS4
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Need more power
Post by Nige_RS4 » Fri Jan 02, 2009 10:34 am
Hold on, you already have 200cel cats in the RS4 downpipes - they are good! Remove the pre-cats as per advice above, then tweak you boost slightly to 1.6bar peak and play with the timing. That lot should be worth 20-30hp. If you want more then a milltek (or custom?) catback will add another 10-20hp.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
matias
Post by matias » Fri Jan 02, 2009 10:56 am
Yes Nige, but isent there a diffrent from 200 cell OEM to 200 cell sportscat.. Or is 200 cell the same whatever it is OEM or sportscat?
What is the best sparksplugs I can go for? RS4 OEM?
