How do i remove front bumper on a RS4 B5?
2.7 V6 30v biturbo - 380 bhp
2ny
Post by 2ny » Fri Dec 05, 2008 9:50 pm
Does someone know how to remove the front bumper of an RS4 B5?
Virdee Autos
Trader (Expired)
RE: How do i remove front bumper on a RS4 B5?
Post by Virdee Autos » Fri Dec 05, 2008 10:09 pm
Remove 3 Torx bolts on either arch liner.
Remove 2 alan bolts holding the bumper to the wing on each side
Remove engine belly pan, or if you don't have access to a ramp, then just unscrew the 3/4 screws holding the belly pan to the bumper
Remove front fog lamp grilles. Undo 6mm(?) alan bolts holding bumper to the bumper shocks/reinforcement.
Disconnect fog lamp wiring, and headlamp washer hose.
I think thats about it!
HTH
Virdee Autos ~ 07950-526592
2ny
Re: RE: How do i remove front bumper on a RS4 B5?
Post by 2ny » Fri Dec 05, 2008 11:29 pm
Virdee Autos wrote:Remove 3 Torx bolts on either arch liner.
HTH
do you have any pics of it?
Virdee Autos
Trader (Expired)
RE: Re: RE: How do i remove front bumper on a RS4 B5?
Post by Virdee Autos » Fri Dec 05, 2008 11:51 pm
Unfortunately not
But all will become clear.
2ny
Re: RE: Re: RE: How do i remove front bumper on a RS4 B5?
Post by 2ny » Sat Dec 06, 2008 12:38 am
Virdee Autos wrote:Unfortunately not
Okey thanks alot anyway, ill try to get it down tomorrow. :D
SimonC
RE: Re: RE: Re: RE: How do i remove front bumper on a RS4 B5
Post by SimonC » Sat Dec 06, 2008 7:24 am
This might help (RS4 Self Study Guide from the "downloads" area of this site).
http://rs246.com/downloads/AudiRS4B5/Do ... 0Guide.pdf
2ny
Post by 2ny » Sat Dec 06, 2008 11:00 am
Thanks for that one, does somone has the workshop manual? because this one reffers to the workshop manual sometimes. :D
2ny
Post by 2ny » Sun Dec 07, 2008 12:04 am
HTH
i tok it down this morning it was pretty easy, when you had the right tools and you explaination.
Thanks alot.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sun Dec 07, 2008 12:29 am
No problems, glad to be of help!
mikeyquattro
Post by mikeyquattro » Fri Dec 12, 2008 10:33 am
What else is involed to get the front end in the service position?
Tomorrow is another day
okkim
Post by okkim » Fri Dec 12, 2008 2:08 pm
Not much, just unbolt the bumber supports and the bolts that hold the radiator frame in place.
Then you can pull the frame forward. You can use the long bumper bolts in the bumper supports bolt place to hold the frame up.
