s3 wuurring noise from rear of car. please help
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
jaiscossie
Post by jaiscossie » Mon Nov 10, 2008 10:50 am
Got this noise on my s3 it starts at about 40mph and is a wuurring noise that sounds like its coming from the rear of the car.Does anyone know what it could be? seems to go away when the car is under load. Its a 2000 s3.Thanks
david7m
RE: s3 wuurring noise from rear of car. please help
Post by david7m » Tue Nov 11, 2008 11:09 am
Doesn't sound good :(
How many miles has it done? Got service history etc.?
You could try swapping the front tires to the rear and vice versa to eliminate the wheels being out of balance. Dont swap left to right if the tyres are directional ;)
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
jaiscossie
Post by jaiscossie » Tue Nov 11, 2008 7:24 pm
It has done 120,000 miles has full service history though, mostly audi, the guy i brought it off said he had 18s on it before and never used to do it.Is there anything else it could be at the rear? thanks
david7m
Post by david7m » Wed Nov 12, 2008 9:58 am
The easy/cheap option is to swap the wheels front to rear. Could be anything, but if it disappears under load, could it be related to the rear diff?
jaiscossie
Post by jaiscossie » Thu Nov 13, 2008 7:09 pm
Would swapping the wheels from front to rear help then? as all the wheels seem ok
graemep
Post by graemep » Thu Nov 13, 2008 8:27 pm
The main point of swapping from back to front would be to see if the noise moves with the wheel.
If it does then it might be that the tyre is deformed, wheel needs balanced, or is buckled - saves looking for something more serious. I've had similar when the sidewalls of the rear tyres of a previous car were knackered.
david7m
Post by david7m » Fri Nov 14, 2008 11:00 am
Its something easy/free you can try to eliminate things.
david7m
Post by david7m » Mon Nov 17, 2008 12:29 pm
Any luck?
jaiscossie
Post by jaiscossie » Mon Nov 17, 2008 3:15 pm
Not yet had other problems since :(
david7m
Re: RE: s3 wuurring noise from rear of car. please help
Post by david7m » Mon Nov 17, 2008 3:26 pm
jaiscossie wrote:Not yet had other problems since :(
jaiscossie
RE: Re: RE: s3 wuurring noise from rear of car. please help
Post by jaiscossie » Mon Nov 17, 2008 3:50 pm
Car burst a hose today on the motorway and dumped all the coolant on the road, not sure its leaking from so need to get it to a garage
Return to “S3 (Typ 8L) 1999-2003”
