Brake pads - for goodness' sake
Lancia
Post by Lancia » Wed Oct 15, 2008 12:26 am
Project U actually sell them for the RS4, only in Race compoundbut find them suprisingly good from cold. No backing plates, but have backing plates from an RS6 Im going to try this arvo. The compound also squeels so probably not the preffered solution for most. Also handle track use very well although after 8 times I just had one fall to pieces. :?
Lancia
Post by Lancia » Thu Oct 16, 2008 11:20 pm
OK,RS6 shims work a treat with these pads. The other thing to look out for is the inner slot needs to be filed out a bit to ensure proper fitament. The guys who fit these originally shoved them in so no movement. Highly recommend these. Got 12 months and around 8 track days out of them. Work good from cold and work well on the track. Rotor wear was respectable as well.
rjkflyer
Post by rjkflyer » Fri Oct 17, 2008 3:01 am
Just to be clear the reason they need 'filing' out is that they are RS6 pads NOT RS4 pads. That slot is exactly the difference, which is why Audi have different part nos for RS4 vs RS6 pads.
The risk is that these bloody numpties do force them in which may jam them.
Lancia
Post by Lancia » Tue Oct 21, 2008 10:59 am
Exactly, they need to be able to move freely at all temps. The Project U ones I am guessing are probably designed off the RS6 backing plate thus why the filing. The horible colour they paint there parts doesnt help either.
Also the squeeling has started after a track day again on these pads. Not the noise from not having shims the noise from having hard pads. I wouldnt recommend these unless your doing alot of track work. Im thinking of changing to stocks again for the street. I dont do that much track stuff.
rjkflyer
Post by rjkflyer » Thu Oct 23, 2008 7:50 am
So, having established that aside the 400 quid PAgids:
1. DS2500s not supplied with shims so unusable
2. YellowStuff DP41513 are RS6 not RS4 pads.
3. YellowStuff RS4 pads not due to hit the streets for 6-8 months
I have succumbed to the YS (due to a racing mate's recommendation) RS6 pads and decided to do a pukka job:
1. machine out the slots (it's a very small amount)
2. passivate the steel to reduce likelihood of it rusting
3. enamel them to protect further where machined down.
Will put them in soonish and report back...!
Lancia
Post by Lancia » Sat Oct 25, 2008 9:40 pm
Be intersted to know the results. The local mechanic "Audi" here got hold of the RS6 shims which I used. See if you can get some old ones for the DS2500's. Mind you his same recommendation was DS2500's would be no good on such a heavy car and go straight to DS3000's.
rjkflyer
Post by rjkflyer » Sun Oct 26, 2008 9:56 am
Hi Lancia, interesting - i spoke to Ferodo and they discouraged me strongly from using the 3000s at all on a road car!
Have installed the Yellows and done some 'burning in'...! P***ing down now of course, so will need to wait for report back!
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 107 guests
