can you tell my wife that 07789 839666Possible galzing the brakes need to be abused no and then to get the optimum grip
Fitting B7 calpers and disks on B5 RS4
neckarsulm
- quattrokid1
- Top Gear
I assume this was for the front calipers, pads and discs only??S4INT wrote:From memory, when I had the B7 calipers & discs fitted by MRC, it was about £1200.
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
I'm sure that was a fitted price, but you would need to clarify with Doug. I had mine done over a year ago and the paperwork went with the car.
Their website quotes this though: http://www.mrctuning.com/brakekits4rs4b7.php £1250 + VAT
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
- boxerdogted
helloGolich wrote: On a slightly different subject both Brooner and Clive are suffering from a spongey peddle despite both of them having their systems bleed several times. Having felt Brooner�s peddle I�m convinced there is still air in his system and suggested they take the calliper off and rotate and tap it while bleeding. The only other thing I can think it might be is under sized master cylinder. Can anyone tell me if the RS6/B7 RS4 has a larger master cylinder than the B5 RS4 � anyone with ETKA ?
Do any of you guys with 6 and 8 pot systems suffer from an initially spongey brake peddle firming up towards the end. Also, the peddle typically firms up and travels less upon an immediate second press. This could be indicative of more fluid volume being required to activate the four additional pistons.
1- i've tested 2 RS4 B5 with the RS6/RS4 V8 front kit, all had very spongey peddle
2- that's a good question...
3- i have 6 pots on front axle and 4 pots on rear axle. My peddle is not so spongey.
However, if i use high friction level compound (carbone loraine/pagid yellow) the pedal is less spongey than with street compound.
I think that the spongey feeling depends on the initial "bite".
laurent
RS4 mtm 460 "safety car", Milltek, Koni, Mov'it 6/380-4/322, teamDynamics wheels ------- S6 plus, mtm, H&R, Koni
I'm french (nobody's perfect) sorry for my bad English!
Chaps anyone know if just the B7 rear discs will fit the standard B5 caliper?
My calipers are fine and recently replaced but my rear discs are shot along with the pads... not that I'm planning on scrimping but I've got quite a few car toys to buy this month and they need to be changed before I take the RS on the ring and to Worthersee in 3 weeks time.
TIA Guy
TIA Guy
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
1968 Karmann Ghia
I'm looking into buying a set for the fronts of my pre-facelift 1999 S4, like the one AMD sell with the RS4 discs, pads and calipers secondhand.
What are the differences between the RS6 calipers and the RS4 calipers, will the RS4 ones I am about to purchase fit and if so why do people fit the RS6 calipers instead?
jimbo1234567
- 5th Gear
the rs6 calipers have a small strenghening brace attatched to them but i doubt this makes a difference because the b7 caliper is newer and doesnt use it. apart from that theyre the same.
665 bhp + 586 lbft...
