Not by cc.andybnwc wrote:So has it ever been sorted?
Srs thread says it all. I hope it works for you if you go that way.
Well done I am genuinely please for you and that you are pleased. It's certainly not a case of expecting people to fail or even wishing it upon others. I don't think you are doing anything radical as it happens.f1 wrote:Im not going to get involved in the politics of issue's that customers are having with other dealers/custom-code hq,all i know is that my audi is driving better than it ever has done although it now seems to like drinking a lot more than it did
Anyway if anyone would like to have a ride in my car (i even might let you drive it) then please p.m me or call us.
This map has truely transformed my car it is very strong all through the rev range,i figure i will have to put a clutch in it at some stage but i consider these to be a service item anyway (amazingly its still on the original at 135k)
The next plans for the car are a milltek and maybe a bmc cda as we have seen good improvments on 225bhp audi/seats.
People that know me (i hope) will tell you that i tend to be tooo honest sometimes, much to the detrament of my businesses bank account.
I really didnt want to start an arguement on here, as previously posted choice is important in all walks of life, but i feel sometimes that people seem to think that because a newish company is trying to do something a little different that means that they will utimately fail, because someone else says that they will!
Yes looks good. Interesting as when I was looking at K03/K04 hybrid it appeared to be a bit of an urban myth. Who did the hybrids for you? Are they built on a K03 shaft or K04 shaft?Blue_Thunder wrote:You'll need to get it on the rollers F1! Yours is pulling the same MAF readings as my K04'd S4 and I registered 415bhp on a Dyno Dynamics machine.
Very impressive figure for all that standard stuff. And thousands of pounds cheaper than my set up too!
Hiyadazzer wrote:Yes looks good. Interesting as when I was looking at K03/K04 hybrid it appeared to be a bit of an urban myth. Who did the hybrids for you? Are they built on a K03 shaft or K04 shaft?Blue_Thunder wrote:You'll need to get it on the rollers F1! Yours is pulling the same MAF readings as my K04'd S4 and I registered 415bhp on a Dyno Dynamics machine.
Now that is interesting. I remember speaking with TD in the past and they said they didn't do them. Any idea how much the shaft speed is reduced using the K04 compressor wheel? Would be very interesting to see the RR results. I would have thought it would be suffering from back-pressure top end. Well done if you make the magic 400.f1 wrote:Hiyadazzer wrote:Yes looks good. Interesting as when I was looking at K03/K04 hybrid it appeared to be a bit of an urban myth. Who did the hybrids for you? Are they built on a K03 shaft or K04 shaft?Blue_Thunder wrote:You'll need to get it on the rollers F1! Yours is pulling the same MAF readings as my K04'd S4 and I registered 415bhp on a Dyno Dynamics machine.
Ok the turbo's are based on k03 shafts with k04 compressors they are available through us but are made by turbo dynamics.
Car will be on some local rollers in the next few weeks just to see the actual bhp!
tar
Simon
Why would you expect these turbos to suffer back-pressure if the impellor isn't turning any faster?dazzer wrote:Would be very interesting to see the RR results. I would have thought it would be suffering from back-pressure top end. Well done if you make the magic 400.
