Advice needed on wheel fitment and tyres
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Gizmo
Post by Gizmo » Mon Sep 29, 2008 5:53 pm
I've recently bought some B5 RS4 wheels for my S4, they are et43, do I need spacers to get them to fit correctly? Also do I want 225 or 235 section tyres?
MilkybarKid
RE: Advice needed on wheel fitment and tyres
Post by MilkybarKid » Mon Sep 29, 2008 7:03 pm
Probably, especially if you have new disks and pads.
Not sure about sizes, but id say 235 up front would be over-tyred, but at the back on these i personally think 225 at the back isnt enough.
id go for 235 rear 225 front, with say 30 profile rear and 35 front to even the rolling circumference.
saying that ill probably get shot down soon enough so watch this space :P
MGR
Post by MGR » Mon Sep 29, 2008 7:07 pm
I would have thought the width should be the same front and back being 4wd with a fairly equal torque split and more weight over the front ? Thats what I'd stick to anyway as thats what audi decided on.
I've never lost traction at the rear before the front so would suggest that extra tyre on the back would only increase the understeer characterisitcs.
MilkybarKid
Post by MilkybarKid » Mon Sep 29, 2008 7:36 pm
^ see :D
Very valid point, and its why my mate (owns tyre company) decides what tyres I run!
MGR
Post by MGR » Mon Sep 29, 2008 9:58 pm
MilkybarKid wrote:^ see :D
wasn't trying to ' shoot you down' just my thoughts on it.
andybnwc
Post by andybnwc » Mon Sep 29, 2008 11:46 pm
I might be missing something here but what size are they? 19s are gonna need 235 18s 225 i think
dubwhizz
Post by dubwhizz » Tue Sep 30, 2008 10:45 am
andybnwc wrote:I might be missing something here but what size are they? 19s are gonna need 235 19s 35 i think
^^^ fixed it for ya...
Matt
kies4
Post by kies4 » Tue Sep 30, 2008 11:45 am
if you put wider tires on the back you'll make the understeer much worse, stick with the 225's all round. you will need to reduce the offset of the wheels if they look silly or touch. 235's have rub issues. do not fit a bigger aspect ratio tyre to the back, this will screw the quattro system. I run et25 with 20m spacers, ofset of 45 so you may be ok with et43. the standard s4's suffer from understeer bigger rear tires would make this much worse and not much fun on the limit at all.
S4 Crazy Horse. Ringsticker & MRC black magic.
kies4
Post by kies4 » Tue Sep 30, 2008 11:48 am
ps if they are 19's you'll never get a very good riding/handling car, look good though !!
GDS968
Post by GDS968 » Tue Sep 30, 2008 12:18 pm
kies4 Have you tried 19's and suffered from handling problems, I know Doug runs 19's without handling issues!
philipwalker
Post by philipwalker » Tue Sep 30, 2008 12:21 pm
10mm spacer and 225/40x18 tyre for 8x18 et43 wheel on the B5 S4.
19" is a bit big on the B4 S4, they fit but it will compromise the ride etc.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
MilkybarKid
Post by MilkybarKid » Tue Sep 30, 2008 12:46 pm
Ha no your ok, i was agreeing with you, i just forgot to put in at the end that i have 225s all round :D
Gizmo
Post by Gizmo » Tue Sep 30, 2008 6:17 pm
philipwalker wrote:10mm spacer and 225/40x18 tyre for 8x18 et43 wheel on the B5 S4.
Sorry, forgot to say they were 18". Looking at getting some tyres from Camskill's, any recommendations, nothing to expensive though!
Thanks for your advice guys. :D
andybnwc
Post by andybnwc » Tue Sep 30, 2008 9:10 pm
Matt
sorry i was saying 235s for a 19" and 225s for a 18"
andybnwc
Post by andybnwc » Tue Sep 30, 2008 9:12 pm
kies4 wrote:if you put wider tires on the back you'll make the understeer much worse, stick with the 225's all round. you will need to reduce the offset of the wheels if they look silly or touch. 235's have rub issues. do not fit a bigger aspect ratio tyre to the back, this will screw the quattro system. I run et25 with 20m spacers, ofset of 45 so you may be ok with et43. the standard s4's suffer from understeer bigger rear tires would make this much worse and not much fun on the limit at all.
ET25 with 20m spacers would mean ET05 cant be right or am i just having one of those days today ?
Users browsing this forum: Majestic-12 [Bot] and 29 guests
