anyone else running 200 cell CAT ??
murgelloMatt
Post by murgelloMatt » Sun Sep 28, 2008 9:28 am
As title i am running 200 cell CAT, full resonated milltek and AMD map. The engine management light has now come on a total of 5 times and the code is saying that both CATs have failed. Have checked the CATs and they are fine so took it to AMD again and they are telling me it is the map. They have adjusted it twice but it still aint right. It also runs really bad on cold start up. I am waiting for the light to come on again!!
Has anyone else had any probs ????
2007 Murgello Blue RS4 B7 Avant, High Flow Cats, Non Res Milltek, AMD Map, Solar Roof, the list goes on...........!
murgelloMatt
RE: anyone else running 200 cell CAT ??
Post by murgelloMatt » Sun Sep 28, 2008 9:30 am
also i would like to add that i had no problem when the non res pipes were on the car ( had to lose them as the noise was to much and i do alot of miles
murgelloMatt
Post by murgelloMatt » Sun Sep 28, 2008 9:57 am
Another thing i have heard that a couple of tuners have had to take the cat of and put OE back on as they could not solve the problem ( kim collins )
P_G
Post by P_G » Sun Sep 28, 2008 10:07 am
One way to solve it is to have something akin to a Lambda sensor chamber. Lambda sensors normally slot into a place near the cats, when I have my S4 fitted with 200 cell cats and a s/s exhaust the custom fitter I used built a separate chamber for them as part of the system so they did not take readings directly from the gas flow through the cats as he had also heard of similar issues but providing an emmissions control system environement that would still allow them to perform a function.
I can't see how it is the map unless they have altered the fueling and ignition sequencing that causes the problem, but then it would have cused a problem from the start and not now.
I will also say at this point I don't know the exact ins and outs of how these things work however that was what I was advised.
Andyuk911
Post by Andyuk911 » Sun Sep 28, 2008 10:52 am
Interesting post, have you ever dynoed the car ?
RS4 Avant - Sold Aug 2009
murgelloMatt
Post by murgelloMatt » Sun Sep 28, 2008 11:27 am
yes mate an awful lot of dyno done
standard 387 horse
exhaust & map 408
if memory serves me right
S2tuner
Trader (Expired)
Post by S2tuner » Sun Sep 28, 2008 12:02 pm
Cat diagnostics can be reprogrammed so the ECU allows 200 or 100 cell cats to work without any problems, but SOME tuners just don't know how to do it.
murgelloMatt
Post by murgelloMatt » Sun Sep 28, 2008 6:05 pm
so who can do it ????
AMD cant seem to sort it ????
S2tuner
Trader (Expired)
Post by S2tuner » Sun Sep 28, 2008 6:47 pm
We can.
murgelloMatt
Post by murgelloMatt » Sun Sep 28, 2008 7:18 pm
based where ????
Oxford ?
murgelloMatt
Post by murgelloMatt » Sun Sep 28, 2008 7:25 pm
ok just seen link ??
will give you a call if AMD do me a refund and stop messing around!!
gotta wait for the light to return, normally only 2 or 3 tanks of fuel
RED_ROCKET
Post by RED_ROCKET » Sun Sep 28, 2008 7:39 pm
Go to MRC they know what there doing.
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
P_G
Post by P_G » Sun Sep 28, 2008 8:02 pm
murgelloMatt wrote:based where ????
Oxford ?
Matt,
If you need someone close to Oxford try Weltmeister / WRC Technologies otherwise as said MRC.
S2tuner
Trader (Expired)
Post by S2tuner » Sun Sep 28, 2008 8:06 pm
Matt, we are based in Banbury :)
caldy
200 Cell Cats
Post by caldy » Mon Sep 29, 2008 7:55 am
Had my custom exhaust, including 200 cel cats, fitted by AAS Exhausts in Newcastle. Drove to Holland for re-map by JDE and no problems whatsoever some 1500 miles on. Both AAS and JDE are very good at what they do.
RS4 B7 Phantom Black
