I purchased a pair of bailey dv30 recirc valves for the s4
When I installed them and went for a spin I cannot hear them dumping at all
the stock ones (710a) I could hear no problem
this does not bother me but I thought it was strange
the car doesnt feel any different power wise
Also when I took the old valves off I can blow through them from charge pressure side to vacuum pipe, the bailey ones I cannot
Is that normal?
dump valves
- SimonS4MTM
- Top Gear
RE: dump valves
FYI, they are re-circulating so you should not here any chav whoosh whoosh!
RE: dump valves
you should be able to test them with a hand vacuum pump and see the valves actuate.
If they don't hold negative pressure then they are mullered.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
Re: RE: dump valves
I know i shouldnt beable to hear any chav woosh, I DONT want toSimonS4MTM wrote:FYI, they are re-circulating so you should not here any chav whoosh whoosh!
what i am saying is i could hear the standard ones, the baileys ones i cant
