Suspension overhaul
2.7 V6 30v biturbo - 380 bhp
A20LEE
Suspension overhaul
Post by A20LEE » Fri Aug 22, 2008 2:42 pm
In the process of collecting parts for the suspension overhaul, and looking at replacing all the bushes front and rear. My thoughts are at the moment poly bush everything apart from the bushes that mount to the subframes thus sharpening things up but not increasing any transmitted vibration. Anyone else gone this route? Order the factory C links for the front, RS2 droplinks for the rear and spoke to MRC about the strengthened subframe mounts so far, ooh and got a H&R Fat ARB kit tucked away too.
Any advice?
andream88
RE: Suspension overhaul
Post by andream88 » Fri Aug 22, 2008 6:36 pm
034 Motorsport is now offering a set of subframe bushings for 180$ (front OR rear, so for a complete set you'll have to spend 360$).
For the C links go this route:
http://www.audizine.com/forum/showpost. ... stcount=15
I'm replacing all the bushes front and rear too, with Powerflex ones.
Upgraded Motor/Trans mounts (034 Motorsport) also help.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
A20LEE
Post by A20LEE » Fri Aug 22, 2008 6:47 pm
thanks for the advise. Are you doing the top mounts too?
andream88
Post by andream88 » Fri Aug 22, 2008 7:57 pm
What do you mean with top mounts?
tnx
Rs4 b5 06/2001
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Aug 23, 2008 6:05 pm
those c links won't last long without rubber boots.
http://www.MRCtuning.com
A20LEE
Re: RE: Suspension overhaul
Post by A20LEE » Sat Aug 23, 2008 6:16 pm
Doug_S2 wrote:those c links won't last long without rubber boots.
What do you mean by rubber boots? An chance you'll have the strengthening plates in stock by the end of this coming week? Like to get them fit on saturday for the drive down to Edition 38.
Doug_S2
Trader (Expired)
RE: Re: RE: Suspension overhaul
Post by Doug_S2 » Sat Aug 23, 2008 6:33 pm
the scooby droplinks have open balljoints - they will wear really quick without protection.
give us a shout middle of the week on the strenghteners.
A20LEE
Re: RE: Re: RE: Suspension overhaul
Post by A20LEE » Sat Aug 23, 2008 6:58 pm
Doug_S2 wrote:the scooby droplinks have open balljoints - they will wear really quick without protection.
cheers, will do.
A20LEE
RE: Re: RE: Re: RE: Suspension overhaul
Post by A20LEE » Fri Sep 26, 2008 2:45 pm
I've been spending some quality time under my wheel arches replacing the wheel bearings/CV's boots and hub flanges and notice the suspension link arms have ball joints on the end. So is it better to renew the whole arm rather than poly bushing or replacing OEM bushes if the ball joints could be worn?
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Sep 26, 2008 7:46 pm
IF your talking about the arms, then you can't buy the ball joints seperately.
Any reason why you changed your hub flanges, and were your bearings shot?
Virdee Autos ~ 07950-526592
A20LEE
Re: RE: Re: RE: Re: RE: Suspension overhaul
Post by A20LEE » Fri Sep 26, 2008 8:04 pm
Virdee Autos wrote:IF your talking about the arms, then you can't buy the ball joints seperately.
because they were cheap on ebay from stafford audi and thought why not? One of the bearing is humming to decide to do both fronts and the CV boots.
Virdee Autos
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Suspension overhaul
Post by Virdee Autos » Fri Sep 26, 2008 8:12 pm
Yeh they're prone to CV boots, infact the whole B5 range incl. Passats!
Bearings are also surprisingly common to the S/RS4's aswell.
Good luck with the rest of your suspension overhaul!
flashyg
Post by flashyg » Wed Oct 01, 2008 8:40 pm
Yes "What do you mean with top mounts?
tnx"
lengster1
Post by lengster1 » Fri Oct 03, 2008 10:34 pm
Mines in for a stint in the garage for a full checkover,considered poly bushes but wary of making the ride even harder or increasing tramlining,anyone done it yet and give feedback
A20LEE
Re: RE: Re: RE: Re: RE: Re: RE: Suspension overhaul
Post by A20LEE » Mon Dec 08, 2008 8:12 am
flashyg wrote:Yes "What do you mean with top mounts?
tnx"
Part number 2 in the picture,
And parts 2,8,9,10
I'm guessing that if you replace the suspension it wouldbe stupid not replace these parts as they will be knackered?
