Who's running 550+
Who's running 550+
Just wanted to hear from anyone who's running R(S4)'s with 550+ , pref RS6 turbos..
Is it a complete animal that will bite your nuts off , or are they civilised until you start to crack on?
I'll be going with the above spec very soon and was wondering how far to go!
- mikeyquattro
- Top Gear
- 5th Gear
RE: Who
i can tell you in about a week
665 bhp + 586 lbft...
911TT, you may need to consider upgrading quite a few other bits along the way if you're aiming for 550+bhp i.e. clutch, brakes, suspension, injectors, IC's, manifolds, downpipes, exhaust.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: Who's running 550+
I'm running 592 bhp with that spec. Just got my car back fomr MRC a week or so ago. They are very tame til you get to 3000 rpm when the turbos really start to hit boost. Full boost (2 bar) is not until near 4k so it's a lot different than the std set up (it was running 470 bhp before that and you get a proper torque kick in the back at 2500 rpm).911TT wrote:Just wanted to hear from anyone who's running R(S4)'s with 550+ , pref RS6 turbos..
However, when you get full boost it is unbelievably quick. Way quicker than my 400 bhp tuscan and about the same as my 500 bhp cosworth (but with more usable power as the turbos start to spool at 2500 rpm whereas the cossie gives you absolutely nothing til 4k).
The only thing that takes some getting used to is the lightweight flywheel (the engine spins up so much quicker) and the heavy duty clutch (which snatches a bit) so the first few take aways from the lights are a little embarrassing!.
Otherwise, yes it is a lot of money but what a sleeper!!!
1995 (M) Noggie RS2. MD357 turbo and remap. tba bhp.
2000 (X) Noggie RS4. Miltek Cat back. No cats. B7 discs/RS6 calipers. ally flywheel, DUH FMIC, ceramic coated tubular manilfolds, large intake pipes, RS6 turbos, 3" downpipea, large injectors etc MRC remap, 592bhp, 535lbft
1990 (Q) 20vURQuattro. Being fitted with RS4 motor & 6 speeder,porsche brakes.
RE: Re: Who
Thanks for the info . Now I'm started to get excited :-0
RE: Re: Who
I have over 550bhp - but not the Rs6 turbos as I feel they take too long to spool up, so I have the K04 hybrids, which IMHO work better.
It really depends on if you want top end grunt or more low down punch - but mine pulls like a train all the way up in 6th, and is so quick through the gears - it's all down to personal choice.
Good luck with it all - still not convinced it's all worth the expence...but thats another story.
R.
R.
RS4 Misano Red (The Fast Colour) - A Few Extras = 550bhp - In Love Again - Now broken - Hate the Bitch... Has to go...
GT-R arriving 14/05/09 - Too many toys - not enough time...
I is running 509bhp, what's the next stage from this, what sort of mods will I need for 550-600?
Have sportscats, full system, manifolds, hybrid turbo's, water injection and have had full engine rebuild in preparation for the additional power.
Flywheel and stupid clutch is done too, along with usual brakes, suspension etc................
MTM air freshner,
98ron V Power,
Child seat
509 bhp
It all depends on what sort of hybrids they are. We do not advise using K04 hybrids for high speed and abusive track usage, as the top end gets restricted by the hot side housings, leading to high oil temperatures and EGTs. RS6 turbos are much better suited for this type of use, due to their larger hot sides.911TT wrote:I'm no expert, but I think you'll def. need to get either Bigger SMIC or a FMIC and some larger injectors, I think hybrid K04's are good for up to 550, then its either RS6 turbos or nutter GTs
Oh of course, 'another' remap
AFAIK the turbo's are Hybrid K04's with 360 bearings, cutback turbine blades and larger comp wheels. I have done loads of track days, Nurburgrings and high speed runs, and TBH never had ANY overheating or similar issues with it, I guess the water injection keeps the ACT's really low.
MTM air freshner,
98ron V Power,
Child seat
509 bhp
Users browsing this forum: No registered users and 74 guests
