Will do.. The brakes are rs6 8pot with 365mm discs.Stigter wrote:B7 rs4 brakes - very nice. Good luck getting to the bottom of this and keep the forum posted.
Rs4 won`t start after turbo replacement
Re: RE: Re: RE: Re: RE: Rs4 won`t start after turbo replacem
RE: Re: RE: Re: RE: Re: RE: Rs4 won`t start after turbo repl
My bad. Just saw the rs4 discs. Didn't check for the brace on the outer side of the caliper - lol
Re: RE: Re: RE: Re: RE: Re: RE: Rs4 won`t start after turbo
Stigter wrote:My bad. Just saw the rs4 discs. Didn't check for the brace on the outer side of the caliper - lol
RE: Re: RE: Re: RE: Re: RE: Re: RE: Rs4 won`t start after tu
Can I ask how long it took you to replace them yourself, in total?
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
RE: Re: RE: Re: RE: Rs4 won`t start after turbo replacement
ignition module on the top of the airbox?
Would still start but would run poor, have you checked all your hall senders and tensioners all so like quattronutter check the earth's are you getting the ecu light on the clocks when ingition is on?dummi wrote:ignition module on the top of the airbox?
1.9TDI A6 are sh*t wrong forum
Have been checking some today,and seems that when i turn the ignition on there is no power to either the fuel pump or ecu.
I measured 0v on the fuel pump and ecu fuses aswell..
It took me about 5hours to remove the engine 2 hours to replace the turbos and about 5 hours to mont the engine back in.
And now an endless amount of hours seaching for the fault..
I found the problem after some research. Some how the ecu has got some moist inside so it did not work. Sendt it to a company that fixes ecu`s and it it now fixed and hopefully installed tomorrow... 3months without my rs4 is quite boring
Users browsing this forum: No registered users and 23 guests
