KW V'3
KW V'3
I can now supply and fit kw v'3 for the B7 rs4 . This will replace the "terrible" drc system that is affecting the cars.
The v3 kit is fully adjustable and will be fitted with new rubber top mounts.
The kit fully fitted is £1700.00 inc vat . grizz
Unit 20
0151 3366888
0151 3366888
RE: KW V
The wirral nr chester. g
Unit 20
0151 3366888
0151 3366888
yes .
Unit 20
0151 3366888
0151 3366888
Thanks .
Unit 20
0151 3366888
0151 3366888
Kwv3 is a full adjustable suspension system ( coilovers) I fit them on lots of rs6's that have had the drc fail.
Unit 20
0151 3366888
0151 3366888
Grizz, I remember reading somewhere that there was some sort of issue with adjustability of coilovers after driving on salty roads. However, I also notice from one particular website that the KW V3s perform very well in salt spray tests. I'm assuming this has been borne out by the RS6s out there now running on KW coilovers?
Some kits suffer from corrosion , the kw is one of the best if not the best , they use a plastic locking ring not alloy.
We prep all kits to prevent this . g
Unit 20
0151 3366888
0151 3366888
I can get a bit more discount on the kw's , so as a result i can supply & fit for £1550 .
Hotchkis ARB'S Are also available but would be $600 + vat & duty .
Unit 20
0151 3366888
0151 3366888
Users browsing this forum: Google Adsense [Bot] and 94 guests
