can someone please help me with this errorcode (RS4 B5)?
Hi Guys! i have a problem with my RS4 B5
i get this errorcode,
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
It seems that the thermostat is OK because ill get to about 90degres after about 14minutes slowdriving.
Does someone know where the temp sensor are located? is there only one sensor or 2, ive heard thats theres one black and one brown? not sure.
// Tony
// Tony
- mikeyquattro
- Top Gear
Re: can someone please help me with this errorcode (RS4 B5)?
http://wiki.ross-tech.com/index.php/17704/P1296/004758
Tomorrow is another day
Isnt that very fast? i ment 90degres Celsius.mikeyquattro wrote: I get to 90 degrees in about 5 mins of slow driving
does someone have the workshop manual?
- mikeyquattro
- Top Gear
RE: Re: can someone please help me with this errorcode (RS4
They warm up quickly. Water temp is up to 90 in about 3 miles of driving when I leave home.
I suspect your stat is at fault
Re: RE: Re: can someone please help me with this errorcode (
mikeyquattro wrote:They warm up quickly. Water temp is up to 90 in about 3 miles of driving when I leave home.
I will check the Coolant Temperature Sensor (G62) tonight, i hope thats the one. because it was not that expensive.
il checked the temp today when i was driving to work the temp is att 75 - 80 degrees after 3 miles.
// T
RE: Re: RE: Re: can someone please help me with this errorco
Mine takes 5 mins to 90 degrees C if that with new thermostat.
Before it would take ages to warm up then it would cool down to 60-70
17704/P1296/004758 - Error in Mapped Cooling System
Possible Symptoms
Cold start issues
Possible Causes
Coolant Temperature Sensor (G62) faulty
Coolant Thermostat faulty
Possible Solutions
Check Coolant Temperature Sensor (G62)
Check Coolant Thermostat
Possible Symptoms
Cold start issues
Possible Causes
Possible Solutions
ive got an G62 sensor now and im going to change it tonight, then il found out if thats the problem, i think it is because ive unplugged the old G62 yesterday and got a new fault and the last fault disappeard. il write back if it works.
the G62 sensor fixed the problem, but something els came up.
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
Possible Causes
Air Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
Camshaft Position Sensor (G40) faulty
Possible Solutions
Check Misfire Recognition
Check Air Intake System
Check Fuel Supply
Check Injector(s) and Injector Sealing
Check Ignition Cable(s) and Spark Plug(s)
Check Ignition Coil(s)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Check Camshaft Position Sensor (G40)
Special Notes
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
ive got alot to do.........
Possible Causes
Fuel Supply faulty
Injector(s) faulty
Possible Solutions
Check Fuel Supply
Special Notes
Random misfires can happen for a number of reasons - as the DTC wiki on VAG-COM forums shows... If I were you I'd clear the faults and drive the car as normal, only worry if the engine light comes on stays on with this fault.
Could be something as simple as dodgy fuel, you need to clean the plugs or even new plugs...
Don't worry about it until it's happening all the time...
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
1968 Karmann Ghia
Okej ive cleared the codes, but i think ive have to connect the computer to it and see when im driving when the codes comes back. maybe i should change the fuelfilter? plugs? is that the sparkplugs? im from sweden so my english isnt all to good.
Users browsing this forum: No registered users and 10 guests
