My RS4 Cab now has Voice Recognition
SR71
Post by SR71 » Tue Jun 17, 2008 3:33 pm
My RS4 didn't come with a Bluetooth module because I didn't order either of the Audi phone packages - because I wanted to keep the RS4 steering wheel which you can't do with either of the Audi options as they both replace the RS4 wheel with an MFSW.
Basically if you've got the RS4 steering wheel you haven't got a Bluetooth module (unless you've had it retrofitted).
Thats curious because Craig de-installed my dodgy cradle which leaves me hooking up my phone via BT and I have the RS4 steering wheel (as opposed to the MFSW)...which means the BT module was there from new...
I'm curious....how do I check if my RNS-E will support SDS?
My RNS-E part number is: 8E0 035 192 Q
and I'm running
HW: H73, SW: 0550.
Am I right in thinking only the H, N & R versions of the A4 B7 RNS-E support SDS?
If so, whats the work-around?
Thanks.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
SR71
Post by SR71 » Wed Jun 18, 2008 4:23 pm
PS: MikeD,
The solution to your problem is to get the new "Q" version of the BT module. I recently had this installed in my A3 and the N95 will now (with the Nokia "Contact Downloads" application you can download from the Nokia WWW site) shuffle contact data across to the RNS-E.
However, whilst my wife's Samsung displays this contact data on the RNS-E directory with the appropriate "Firstname", "Lastname" fields, my N95 populates the directory with the numbers!
Which is bloody useless.
Yet to sort this out....anyone any ideas?
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
pippyrips
Post by pippyrips » Wed Jun 18, 2008 4:28 pm
SR71 wrote:PS: MikeD,
Bit of a longshot J but is one phone saving contacts to the simcard while the other is saving to phone memory?
MikeD
Post by MikeD » Wed Jun 18, 2008 4:48 pm
Just got the car back from the stealer's and it turns out that I have version "H" fitted, they are going to ask if I can get version "Q" under guaranty but some how I think not.
S4(b5)Avant ,K04's+Milltek pipes+ECU+full QST
RS4(b7)Avant ,ss+, standard "for now" ,
Ariel Atom 3, 300 with extras!
SR71
Post by SR71 » Wed Jun 18, 2008 7:10 pm
Thats not it.
Both phones are using the phone memory.
I've got a thread running in navplus.us as well as on the Nokia boards looking for insight...
58 C6 RS6 Stage 2+
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
