scoobyc
Post
by scoobyc » Tue Jun 10, 2008 10:19 am
PetrolDave wrote:pippyrips wrote:What’s the general rule of thumb with swapping tyres round ?
Don't.
tyres should be changed occassionally front to back to create even wear , as it says in the owners manual
wait for it......
RS4 Avant - Daytona Grey SOLD
Focus ST wth a tweak
03 911 (996) turbo SOLD
06 Wrx impreza SOLD
PetrolDave
Post
by PetrolDave » Tue Jun 10, 2008 12:50 pm
With all the quattro Audis I've had (S3, 2 x B6 S4, B7 RS4) the difference in wear rate between front and rear is so minimal that there's no benefit swapping front and rear.
scoobyc
Post
by scoobyc » Tue Jun 10, 2008 1:33 pm
surely the shoulders of your front tyres wear quicker than the rears?
wait for it......
06 Wrx impreza SOLD
W8PMC
Post
by W8PMC » Tue Jun 10, 2008 1:56 pm
PetrolDave wrote:With all the quattro Audis I've had (S3, 2 x B6 S4, B7 RS4) the difference in wear rate between front and rear is so minimal that there's no benefit swapping front and rear.
I'd have agreed about Quattro tyre wear until the B7 RS4. Both sets i've been through have shown around 25% more wear on the fronts than the rears & i check the pressures weekly.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
sham
Post
by sham » Tue Jun 10, 2008 6:50 pm
W8PMC wrote:PetrolDave wrote:With all the quattro Audis I've had (S3, 2 x B6 S4, B7 RS4) the difference in wear rate between front and rear is so minimal that there's no benefit swapping front and rear.
similar results with my fronts compared to the rears also
pippyrips
- Top Gear
Post
by pippyrips » Tue Jun 10, 2008 8:32 pm
Yep, I regularly keep an eye on the pressures but the fronts are definitely wearing quicker than the rears at present, (with the front nearside showing the most which I’m putting down to roundabouts as mentioned previously.)
I had the alignment checked when they went on so at least I know its pointing straight!
ChrisRS4
Post
by ChrisRS4 » Thu Jun 12, 2008 5:39 pm
Well, I had my goodyears fitted yesterday (275/30/19) and I have to say I'm not very impressed. They feel alot more 'squidgy' that the PS2's, almost like there's not enough pressure in them even though there all set to 36 psi. Certainlly not as grippy so far.
Marcus-RS4
Post
by Marcus-RS4 » Thu Jun 12, 2008 5:47 pm
Pressure is too low - try 39 front 37 backs - this will sort it out
PetrolDave
Post
by PetrolDave » Thu Jun 12, 2008 5:48 pm
I felt the same at first, but now nearly a week later the 'squidginess' has disappeared.
ChrisRS4
Post
by ChrisRS4 » Thu Jun 12, 2008 6:31 pm
Cheers guys. Marcus, I'll give that a try as they do feel under inflated but I was going by the recommendations of the tyre fitters (not saying I trust them, afterall they haven't got the balance right either). Dave, sounds promising, thanks!
W8PMC
Post
by W8PMC » Fri Jun 13, 2008 9:13 am
I was filled with 36 all round as this was advised upon fitting of the F1's, however folk on here said 38 so i upped them & they feel great. Defo better then the OEM P Zeros & so far appear better then the PS2's i had on the RS6 & M5. Plenty of grip & the road noise/ride is much improved.
Paul
pippyrips
- Top Gear
Post
by pippyrips » Fri Jun 13, 2008 9:25 am
My F1's took a lot longer than previous tyres to scrub in.
P_G
Post
by P_G » Wed Jul 23, 2008 9:55 am
Another satisfied convertee to Goodyear 275/30's Cost all in was £720, £680 for four tyres from mytyres.co.uk and £40 for fitting and disposal from local fitter.
Turn in is much better as is road noise and wet handling over Conti SC3's. Running on 38 all round but I don't believe after 400 miles thay are fully scrubbed yet and giving their fuill potential..
mac4RS
Post
by mac4RS » Wed Jul 23, 2008 10:25 am
Same here. Have had mine a couple of months now, & with more miles they get better...IMHO they feel gr8t compared to my previous PZero Rosso's.
Marcus-RS4
Post
by Marcus-RS4 » Wed Jul 23, 2008 11:15 am
I am running 39 front, 38 rear, I found this gave e optimum turn in, without inducing unnecessary under steer... 1psi makes all the difference
lol
Users browsing this forum: Google [Bot] and 169 guests
