K&N, is it worth it?
2.7 V6 30v biturbo - 380 bhp
dog
Post by dog » Sun Oct 05, 2003 11:44 pm
The local Audi people don't service K&N filters so I have changed back to genuine. I am not sure if K&N makes any difference. My only problem is that lately I cant get better than 5.7s for 0-100. Although the tempreture is getting higher, about 24 degrees in Sydney.When I did 5.2 it was in Melbourne and 14 degrees only.
Ozz
Re: K&N, is it worth it?
Post by Ozz » Mon Oct 06, 2003 12:19 am
You don't need K&N but better engine management, 5.XX is [img]images/graemlins/frown.gif[/img] [img]images/graemlins/033102bad_1_prv.gif[/img]
S4 Autronic 606 Hp, 10.655 ET :)
RS4.org member ... in the past.
kiwi_mtm
Post by kiwi_mtm » Mon Oct 06, 2003 6:32 am
Do have a 600hp S4 !!
[img]images/graemlins/bowdown.gif[/img]
What size turbos do you have in that puppy. List out what you've done, i'm keen to hear!!
Dog, how are you measuring your 0>100 ?
2014 RS6 (2023 on order)
2017 Q7
1993 E36 M3 Tarmac Rally car
2001 Porsche Boxster circuit car
2017 Porsche 991.2 GT3 Clubsport
dog
Post by dog » Mon Oct 06, 2003 2:10 pm
With a G-tech.
I can't make it go any faster than 5.2. But I do not sidestep the clutch either. Any suggestions about take off technics are welcome.
dog
Post by dog » Mon Oct 06, 2003 2:12 pm
Jaroslaw, I thought your car was blue from the RS4.0rg timees...
Sql_PL
Post by Sql_PL » Mon Oct 06, 2003 11:02 pm
well, i think i have seen one blue rs4 from Poland on rs4.org messageboard... [img]images/graemlins/cool.gif[/img]
quattropaul
Post by quattropaul » Mon Oct 06, 2003 11:41 pm
Well i've fitted a K&N Filter to my S2 and i'm well pleased with it.There is a definate improvement in throttle response and a slight improvement in fuel consumption too [img]images/graemlins/thumbs.gif[/img]
DAVIDP20V
Post by DAVIDP20V » Tue Oct 07, 2003 1:04 am
Is that a panel filter or Induction cone thing. because i thought there were problems with heat from turbo ? [img]images/graemlins/033102bad_1_prv.gif[/img]
is this the same with s4's rs4's etc ?
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Dippy
Post by Dippy » Tue Oct 07, 2003 1:20 pm
Dog,
The S4/S4 ECU works rather differently from many other Audi turbos. Located at the throttle body is a pressure sensor. The ECU uses this to sensor (amongst others) to control the wastegates in order to achieve exactly the demanded boost. So unless your car is modified such that the turbos are stuggling to achieve the demanded boost (in which case you'd probably be risking the engine!), there is no performance advantage of increasing induction airflow rate. I would agree that it could give a reliability advantage, unless of course the filter is oiled, which increases the risk of MAF contamination.
2001 Silver S4 Avant
johneroberts
Post by johneroberts » Tue Oct 07, 2003 10:24 pm
In a word "NO" its not essential but it just makes it feel better [img]images/graemlins/grin.gif[/img]
Personally ive always used K&N s in all may cars and i sware by um
jr
Driving is believing
RS246 Founder
DAVIDP20V
Post by DAVIDP20V » Wed Oct 08, 2003 12:02 am
john, is that a panel filter ? or the other type ? [img]images/graemlins/confused.gif[/img]
Davidp20v
PhilT
RS246.com
Post by PhilT » Wed Oct 08, 2003 8:45 am
We use the panels in the RS4. The Induction kits will suffer from the underbonnet heat.
dog
Post by dog » Wed Oct 08, 2003 2:22 pm
Very interesting point Dippy!
Must check it out!
Users browsing this forum: No registered users and 31 guests
