http://www.rs246.com/index.php?name=PNp ... highlight=
Planning on supporting the turbos to the gearbox too... somehow...
So then... time to bash on with the heads... theres 2 outstanding things before the heads go on and thats make the manifolds fit as best as they can be and block off the extra ports that the NA and RS4 heads use but the S4s dont....
So manifold first, not quite done them both but just about there. I sent them back to my welding genius and he tigged the inside of the runners to the inside of the flange so thatthe welds are double up. However that leave a flow restriction so I started flowing them back...
So after welding (before they were welded they were just ends of the tubing exposed, not great for flow...)
So got out my flowing kit!!! stuck on some music.... then put my ear defenders on (good job I put the music on!)... and got cracking.
end result:
quite pleased with that....
now the NA heads have larger ports than the RS4 heads but even with that I think that I could in theory flow the heads a little but Im not going to as the heads are clean and ready to go on.... seee check the gasket out:
See how the ports are smaller than the gasket?
Now on the manifold:
difficult to see but the ports on the manifold are larger than the gasket.... better than the ridiculous restrictions that the standard manifold are!
Ive flowed a few bits and peices mainly alu and steel, but stainless is a lot harder and made short work of my trusty carbide bit!! ah well all in a good cause!!!
Anyway, I fitted the manifold up to the head and it wasnt a great fit. I needed to chamfer the edges of the manifold so there was adequate clearance from the head castings, it might be an NA head thing as the castings are different to the S4 heads....
crap pic, sorry bout that but you can see where I took the angle grinder too...
so was happy with that...
