how "smooth" is your idle ?
Hi all
I've noticed my idle sometimes makes the exhaust wobble and you can see the engine ever so slightly shaking so I Vag-com'ed it and it did'nt come up with any fault codes.
Did a misfire recognition log (measuring blocks 014, 015 and 016) and a run at idle for 10 minutes only produced 2-3 misfires on two cylinders (which I think is normal). Could it be new engine mounts needed ?
cheers
Al
cheers
Al
Have similar issue(s)
1) Slight, annoying, cant diagnose poxing misfires
Gone through the car and done (checked/sorted) all the standard stuff to sort i.e maf, lambdas, plugs, plug boots, vacuum leak check, charge pressure leak checks, coil packs, amplifier tests + 1 replaced, throttle body adapt, fuel trim reset, battery check, battery terminal cleaning etc etc..
Each item showed some improvement - final thing I've done is get some silicone grease on the bottom of the plug boots a) to spark insulate them b) to let them slip over the plug and allow the electrodes to make contact.. as I noticed on a new coil pack for a seat that it had a dab of silicone grease on it as standard.
Seems a lot better now - still occasional wobble but nothing like before.
http://www.maplin.co.uk/Module.aspx?Tab ... 6&doy=22m4
(Look for RE90X - as it comes also as a tube of gunk)
2) wobbly exhaust - found that the last but one exhaust mount has a broken weld - common fault I'm told.
- Virdee Autos
- Trader (Expired)
Some good points there. Mine also does it ever so slightly, nothing major, but enough to annoy me! Can be ok sometimes, and other times worse!
How did you check the ignition amplifiers...resistance?
Also the grease on the tips of the plug end caps is a good idea, something that I will do shortly when I change the plugs.
Virdee Autos ~ 07950-526592
The amp output was plotted on a picoscope setup (http://www.picotech.com/) and it was pretty evident from the trace that the amp was duff - think there's some example traces on the site. In the end just compared the two and a new one on the plot. Did suggest to my mechanic that the simplest way was to swap em over and see if the problem moved, but the coils were'nt tha flash so difficult to spot it this way - compound problem.
One other thing I my well do is to check for corrosion on the ignition relays - read somewhere that this can cause variable voltages to the ECU etc. Either replace or open em up and squirt PCB cleaner on them to remove any oxide. Could be a bit above and beyond the call of duty tho and am poss getting into obsessive compulsive disorder territory!
- boxerdogted
mine had i slight what i would call a shudder now and again but Golichs one and got it checked by Audi that said the couldn't find a problem so maybe just one of those Audi querks you have to live with like the stiff gearbox when cold
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
- Virdee Autos
- Trader (Expired)
I remember reading on here that sometimes the spark plugs can become loose, and create a lumpy/misfire idle.
Users browsing this forum: No registered users and 74 guests
