Fitting B7 calpers and disks on B5 RS4
2.7 V6 30v biturbo - 380 bhp
neckarsulm
Post by neckarsulm » Wed Mar 12, 2008 12:03 pm
Possible galzing the brakes need to be abused no and then to get the optimum grip
can you tell my wife that 07789 839666 :D
Brooner
Post by Brooner » Wed Mar 12, 2008 5:56 pm
:biggrin3: just say your avoiding hitting a little bunny i'm sure she will sympathize
quattrokid1
Post by quattrokid1 » Wed Mar 12, 2008 6:57 pm
S4INT wrote:From memory, when I had the B7 calipers & discs fitted by MRC, it was about £1200.
I assume this was for the front calipers, pads and discs only??
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
TopBear
Post by TopBear » Wed Mar 12, 2008 8:23 pm
You should clarify whether that MRC price includes fitting, as I think its parts only.
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
S4INT
Post by S4INT » Wed Mar 12, 2008 8:43 pm
I'm sure that was a fitted price, but you would need to clarify with Doug. I had mine done over a year ago and the paperwork went with the car.
Their website quotes this though: http://www.mrctuning.com/brakekits4rs4b7.php £1250 + VAT
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
Durit
Post by Durit » Wed Apr 02, 2008 11:45 am
Hi
can you tell me the diameter of the rear caliper's pot (B7)?
Thank you.
RS4 mtm 460 "safety car", Milltek, Koni, Mov'it 6/380-4/322, teamDynamics wheels ------- S6 plus, mtm, H&R, Koni
I'm french (nobody's perfect) sorry for my bad English!
jc..
Post by jc.. » Wed Apr 09, 2008 8:14 pm
2 questions:
1) is there a difference in the dimensions and offset of a RS4 B7 front disc and the RS4 B5 front discs?
2) Do B% RS4's and S4's share the same hub carrier (strut)
in short what is to stop me doing this on a B5 S4 with B5 RS4 discs?
OK so that was three!
jc..
Post by jc.. » Sun Apr 13, 2008 8:34 pm
no-one?
boxerdogted
Post by boxerdogted » Sun Apr 13, 2008 8:43 pm
Yes you can fit B5 RS4 discs, the offset must be the same as you can fit RS6 and B7 RS4 calipers to either car without special brackets , you only need different brackets if you use RS6 Discs as they do have a different offset.
The B5 disc is 360mm and the b7 is 365mm.
2001 RS4 Misano Red
Durit
Post by Durit » Mon Apr 14, 2008 11:31 am
Golich wrote: On a slightly different subject both Brooner and Clive are suffering from a spongey peddle despite both of them having their systems bleed several times. Having felt Brooner�s peddle I�m convinced there is still air in his system and suggested they take the calliper off and rotate and tap it while bleeding. The only other thing I can think it might be is under sized master cylinder. Can anyone tell me if the RS6/B7 RS4 has a larger master cylinder than the B5 RS4 � anyone with ETKA ?
Do any of you guys with 6 and 8 pot systems suffer from an initially spongey brake peddle firming up towards the end. Also, the peddle typically firms up and travels less upon an immediate second press. This could be indicative of more fluid volume being required to activate the four additional pistons.
hello
1- i've tested 2 RS4 B5 with the RS6/RS4 V8 front kit, all had very spongey peddle
2- that's a good question...
3- i have 6 pots on front axle and 4 pots on rear axle. My peddle is not so spongey.
However, if i use high friction level compound (carbone loraine/pagid yellow) the pedal is less spongey than with street compound.
I think that the spongey feeling depends on the initial "bite".
laurent
R5YUG
Post by R5YUG » Mon Apr 28, 2008 9:20 pm
Chaps anyone know if just the B7 rear discs will fit the standard B5 caliper?
My calipers are fine and recently replaced but my rear discs are shot along with the pads... not that I'm planning on scrimping but I've got quite a few car toys to buy this month and they need to be changed before I take the RS on the ring and to Worthersee in 3 weeks time.
TIA Guy
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
h8cak
Post by h8cak » Mon Jun 02, 2008 7:32 pm
When you say Rs4 rear caliper brackets 8E0 615 425D �262.00 the pair do u mean the carrier? Or is there a seperate bracket i need?
Wide Body S4
Tom-S4
Post by Tom-S4 » Thu Oct 09, 2008 5:48 pm
I'm looking into buying a set for the fronts of my pre-facelift 1999 S4, like the one AMD sell with the RS4 discs, pads and calipers secondhand.
What are the differences between the RS6 calipers and the RS4 calipers, will the RS4 ones I am about to purchase fit and if so why do people fit the RS6 calipers instead?
jimbo1234567
Post by jimbo1234567 » Thu Oct 09, 2008 6:17 pm
the rs6 calipers have a small strenghening brace attatched to them but i doubt this makes a difference because the b7 caliper is newer and doesnt use it. apart from that theyre the same.
Users browsing this forum: Google [Bot] and 113 guests
