wires
wires
are there any switch live wires in the engine bay which is adequate for the the relay on a water injection set up. doesn't have to be a powerful one. just dont want to hook into an ecu or important one. what about one under the passenger side.?
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
RE: wires
just open up the ECU box and feed a wire from the fuse board and pass it through the box..safer that way..and it,ll be fuse protected..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
lift the ecu out. then drop your wire down the hole. With a bit of luck you'll find it near the brake pedal. or if not drop a straightened coat hanger down then tape your wire to it from the inside. Then in the engine bay retrieve your coat hanger.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
Have a look at the install instructions for the AWE boost gauge here - http://www.awe-tuning.com/media/pdf/ventgauge.pdf (300kb)
Step 11 shows you it, its where I have my gauge wired here for the lights and it only comes on with the ignition.
Its just in the fuse box area by the drivers side, just drop the lower panel down to get at it.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
ok got the wire in. found a load of other stuff under there. a charging lead to something. see pics.
also looks like a relay is missing. any ideas.?
- Attachments
- audi car bit 004.jpg (144.04 KiB) Viewed 1688 times
- audi car bit 001.jpg (133.09 KiB) Viewed 1687 times
