B5 S4 Rear Brake Upgrade Options
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
ZeroK66
Post by ZeroK66 » Wed Apr 09, 2008 10:50 am
Morning all,
This topic seems to have been done over a few times but is very scattered over various topics. I hope to start a thread that is condensed and focused on what our options are to help me and others in the future.
My rear brakes need replacing as I need new pads and disks. Fortunately I own a facelift S4 with vented disks. This of course is the first upgrade option for those with pre-facelift cars.
Pre-facelift std = 245 x 12mm solid discs
Facelift std = 255 x 22mm vented discs
Options found so far as follows:
UPGRADE OPTIONS:
Option 1 - Thanks to UKS4APR1. MarkB will be fitting these soon to his car
http://www.rs246.com/index.php?name=PNp ... ic&t=67872
For NON-FACELIFT CARS <1999.5
034 Motorsport B6/7 Rear disks w/ Spacers & refurb facelift callipers
http://www.034motorsport.com/product_in ... ts_id=1170
300x22mm Discs
OEM B5 S4 Facelift Callipers
Spacer to move Calliper out
Longer Brake Lines
FULL KIT for pre-facelift cars - £??? (US$800ish?) + pads + brake lines
FOR FACELIFT CARS >1999
034 Motorport B7 S4 upgrade Brackets alone - US$75.00
http://www.034motorsport.com/product_in ... ts_id=1146
B7 S4 300x22mm Discs - £90.00 (45x2) - Price by Alan@VAG-Parts
Brake lines - £50ish???
FULL KIT for facelift cars - £180ish + new pads if needed
Option 2:
FOR BOTH PRE & POST FACELIFT CARS
RS4 B7 Rear Brake Upgrade Kit - £750+VAT (Quoted by MRC)
324 x 22mm discs cross drilled & vented discs (£200.41+VAT each!!)
Larger callipers etc etc
Option 3:
This gets to silly money. I will just refer to one option I have priced by MRC. This is for an equivalent setup to the R8
Brembo 4-pot rear callipers equivalent to R8
I am not sure on the disc information
£2500+VAT
A lot of the information on this post has come through MRC or Alan at Vag parts. Alan is very knowledgeable & has been a great help.
According to Alan the B5 and most modern Audi's - the rear brakes only contribute 20% of the braking force to the car.
Based on all of this I think I am going to go with the B7 rear disc upgrade with the spacers from 034 motorsport. Seems best value for money. Going to try and get some cross drilled after market discs for cosmetic appeal.
Hope this helps anyone looking to do upgrades in the future.
bobbler
RE: B5 S4 Rear Brake Upgrade Options
Post by bobbler » Wed Apr 09, 2008 12:37 pm
Cheers ZeroK for taking the time to put this together. Just starting to look at rear upgrades now that my fronts are done as it feels as though there is nothing back there at the moment in comparison to the up front stoppers.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Apr 09, 2008 4:10 pm
Just fitted a full Rear brake kit from a B5 RS4. works very well
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
MarkB
Post by MarkB » Wed Apr 09, 2008 4:19 pm
I'm going the B7 S4 route with adapters for the standard calipers...
Mark
s4woody
Post by s4woody » Wed Apr 09, 2008 7:22 pm
you could also go the RS6 route..
GARTH ROAD MOT CENTRE LTD
020 83353032
JDB
Post by JDB » Thu Apr 10, 2008 10:01 am
How much are they Woody?? Does it have a hand brake calliper
MarkB
Re: RE: B5 S4 Rear Brake Upgrade Options
Post by MarkB » Thu Apr 10, 2008 10:23 am
s4woody wrote:you could also go the RS6 route..
Isn't the RS6 setup hard to get to fit the rear of the B5's?
Mark
ZeroK66
Post by ZeroK66 » Thu Apr 10, 2008 12:21 pm
Apparently a pig to install & maintain. Doug has this on his car.
Doug_S2
Trader (Expired)
RE: Re: RE: B5 S4 Rear Brake Upgrade Options
Post by Doug_S2 » Fri Apr 11, 2008 9:36 am
i ditched the rs6 rear end and use b7 rs4 rears now.
http://www.MRCtuning.com
s4woody
Post by s4woody » Fri Apr 11, 2008 1:04 pm
isn't that like saying does the RS6 turbos need a diff end on the exhaust to fit them..what a pain thats gonna be...
who said its gonna be easy..
isn't this topic called S4 rear brake options... give me a break FFS...
@JDB i have disc's,calipers and carriers with new backing plates..your,s for £270+ postage...and yes the calipers take the handbrake cable...
020 83353032
Siena
Re: RE: Re: RE: B5 S4 Rear Brake Upgrade Options
Post by Siena » Sun Apr 13, 2008 4:38 pm
Woody, calm down. MarkB was just commenting.
We're all sharing ideas here, loosen up.
tdiquattro
RE: Re: RE: Re: RE: B5 S4 Rear Brake Upgrade Options
Post by tdiquattro » Sun Apr 13, 2008 5:03 pm
The S8 option (280x22mm) is still there and just about manages with existing brake lines etc, so no removing the lines or bleeding the brakes.
The disks are cheaper as well for replacements and there are more options for the disks as they are VAG fronts used on other cars so there are plenty of non OEM aftermarket ones out there, slotted, drilled etc.
The caliper carriers are more expensive than the 034 adapters, but the result is stock audi with no adapters etc.
so there are pros and cons.
http://forums.audiworld.com/s4/msgs/1716040.phtml
Nige'
2000 silver S4 Saloon
s4woody
Post by s4woody » Sun Apr 13, 2008 5:05 pm
i was calm when i wrote it and im still calm..when you've been here for a little longer than 122 posts you will find most things get shot down when they dont seem easy or you aint following a heard of sheep..
what do you think the RS in RS246 stands for...R Sheep 246. com on...
020 83353032
Peakz
Post by Peakz » Sun Apr 13, 2008 6:41 pm
Having looked into this last year I thought the S8 rear setup was the most cost effective route for my purposes.
A year on I have no regrets and the pad wear appears to be normal.
redrod
Post by redrod » Sun Apr 13, 2008 8:30 pm
so many sheep on here I agree........ one mane keeps coming up.... and that is daddy sheep.
RR
