4wd Oversteer
4wd Oversteer
Hi,
Decided to test the 4wd system without ESP today and discovered the thing could actually go 40 degrees sideways. Was caught by surprise and applied opposite lock(1/4 turn).
Is this normal? Would have thought it would have more grip and understeer-must admit it was full throttle out of an empty junction but still. Must be more fun than i thought.....or maybe my rear differential is duff.
Car is bog standard btw.
Re: 4wd Oversteer
a6khu wrote:Hi,
My Gt-Four used to own the junction oversteer.
Slip the clutch a little when pulling off, plant the throttle, and let the clutch the rest of the way out.
It'd go as if a giant had just kicked the back end of the car as hard as possible.
My S4 shows no signs of wanting to do similar.....despite having the same 50/50 mechanical split.
If find the quattro reassuringly surefooted, but I'd say the PFL cars without any traction aids can be quite lively if provoked. You really do have to try harder than you would need to in a 2wd car though.
- 1st Gear
- Top Gear
- 5th Gear
il drive your car and make it go sideways if you want~?????????????????????????Avant sideways must look awesome. I wish someone else would drive the car so I can see it too.
665 bhp + 586 lbft...
