40:60 front/rear split
The two piece diff is slightly different to the 1pc.
I got my two washers from here.
http://simplybearings.co.uk/shop/p8830/ ... 44c287f514
They then need reworked to 43mm x 30mm x 1.47mm
Looking at the diagram the 1pc (later) torsen you will need to replace only one of the washers on the outside and the one in the middle. #1 and #4.
The ones that need to be replaced are the teflon coated ones.
It all seems pretty complicated but I hope it will all be clearer once I get the torsen in bits. I wont be able to do this until may however as I have far to much uni work to get on with at the moment.
